Hackaday.io Hackaday.io
Sign up Log in
3D printable modular mechanic parts
A set of parts made with parametric scripts that can be used to make general purpose robot, and easy to recycle.
siluxmediasiluxmedia
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 2
    • View all
  • Logs 0
  • Instructions 6
    • View all
  • Discussion 0
View Gallery
147
0
6
3
Team (1)
  • siluxmediasiluxmedia
Join this project's team
hardware
ongoing project
This project was created on 08/14/2015 and last updated 10 years ago.
Description
A set of modules made with openscad which have parameters to customize size, dimensions and numbers of holes. The goal is to make a library of pieces that can be configured and printed, which can help the building of robots.
Components
  • 1 × HC-SR04 ultrasonic distance sensor
  • 1 × Dagu Mini Driver Arduino ATmega8 + dual motor driver
Build Instructions
Collapse
  • 1
    Step 1
    Get openscad files from github https://github.com/ValerioCietto/Printable-Meccano
  • 2
    Step 2
    Open files with Openscad
  • 3
    Step 3
    decomment the module you want and set the size.
    //MeccanoC([30,10,4], 4);
    MeccanoC([30,10,4],4);
View all 6 instructions
Log In/Sign up to comment
Sign up with Github
OR
Build Billy McCoy's AT-ST Walker: 18 Steps
Project Owner Contributor
mark-langfordMark Langford
The 2018 Hackaday Prize
m-BITBEAM is a 3D printed construction set based on the Bitbeam concept including some additional parts like wheels, holders, boxes, etc.
m-BITBEAM construction set
matous-pokornyMatous Pokorny
A mid-size quadruped made with off-the-shelf + 3d printed parts.
Dante
778-labs778 Labs
A Construction set. Made of flat pieces. 3D-printer friendly.
K-raft
andrey-kalmatskiyAndrey Kalmatskiy
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "3D printable modular mechanic parts", please tell us the reason.
Send message
Remove Member
