8x8 RGB Matrix display controller
8x8 RGB matrix controller with a TLC5947 from texas
RGB matrix driver ,by a TLC5947 from Texas instrument (SPI) , and a PCF8574 (I2C)
Matrix are chainable
NO MCU on the board , you can use your own favorite MCU , you just need SPI and I2C BUS
Hardware is done , i 'm working on the sofware ( most difficult part for me ...:):) )
Warning : mistake in the Matrix lib on eagle , for the green colors LSB and MSB are inverted , you have to correct it in the software if you dont want to have the green color in mirror mode .....
  • 1 × TLC5947 Interface and IO ICs / Display Interface
  • 1 × PCF8574 Microprocessors, Microcontrollers, DSPs / Microprocessors (MPUs)
  • 1 × UDN2982 Interface and IO ICs / Peripheral Drivers and Actuators
  • 1 × GENTA RGB 8x8 LED MATRIX
  • 1
    Step 1
    PCF8574 do the ROWS , and TLC5947 the colums
    TLC5947 is the most tricky part to understant , it 's a kind of super 288 bit shift register
    TLC5947 need 36 BYTE for lighting a line of the matrix . So you need 288 BYTE for 1 entire Matrix
    and 1152 BYTE for four MATRIX ....
View all instructions
