LED Matrix Display
Putting some surplus LiteOn LTP2558AA modules to use
I came upon a bunch of these 5x8 LED modules while wandering the aisles of our local electronic surplus shop. A tube of 20 of them was $16US and it followed me home. The modules are about 2.3" x 1.4" with each dot supporting red and green. After some searching, the best drivers that I found were the IS32FL3738 chips. In the interest of keeping PCB costs down, I decided to make individual driver PCBs for each module, and mount them on a plate. Two driver chips are required per module, one for red and one for green. The driver chips use an I2C interface, and there are 4 address options. In order to run more than 4 of the chips (2 modules worth), I put an I2C address translator chip on each module. There was no end use for these modules in mind when I found them, but I think I will build a clock that shows the day of the week and date/time.
These LiteOn LTP2558AA LED modules came from the local surplus shop (www.elliottelectronicsupply.com/featured/liteon-ltp2558aa-ra-large-2-4x1-5inch-dot-matrix-red-orange-and-green-leds-gray-face-with-white-dots-in-off-state.html). They have a LOT of these beasts in stock. Usable data sheets were found on the LiteOn web site.
LiteOn LTP2558AA LED Module With a Familiar Object for Scale Reference.
This is my first dive into matrix LED stuff. Driving them seems a little bit like driving a video display, but only sort of. I looked at options for driving them from raw drivers and a SPI interface to fully integrated controller/driver chips. In order to support the red and green LEDs, there are two separate sets of row and column pins on each module. Each of the matrices has its own driver chip. The ISSI IS32FL3738 chips support up to a 6x8 matrix, provide current control and dimming options and two of them will fit on a PCB that sits under each module. They are also readily available and fairly inexpensive. I roughed out an electronic design and laid out a 4 layer PCB to mess with.
Rev 1 Driver PCB test fit on the back of an LED module.
The boards came back from OSH Park and I built up the first one. The two LED controller chips are visible in the center of the board and the I2C address translator (LTC4316) at the lower left corner. The I2C bus and sync signal will route from module to module via the connector on the lower left edge of the board. Power connections will be done in a star configuration ending at the power connector above the bus connector.
From the IS32FL3738 data sheet, it sounded like I needed direct routing from the driver outputs to the LED module pins due to current requirements. The driver chips require half a dozen or so passive components. In order to minimize the routing interuptions, I put the passive components on the back side of the board. There are ground/heat sink pads on the bottom side of the driver chips. In order to get a good solder connection to the pad, I populated the top side of the board and reflowed the solder on my hot plate. The passives on the back side got installed and hand soldered which is a pretty fiddly process.
The rev 1 board was designed with address translation on the upper 3 bits only, with one translation configuration resulting in an undesirable address (0) for the red controller.
In order to simplify the build and get address translation on both the upper and lower nibbles of the address, I did an iteration on the board design. All of the passive components got moved to the top side of the board. I also narrowed the board slightly so that the board fits completely under the module. The new boards have been sent out and should be returning from OSH Park early this week.
Documentation on the IS32FL3738 chips is pretty terse and this is the first time I have messed with them. In order to figure out how to drive the chips, I used a PC based USB to I2C dongle (TotalPhase Systems Aardvark) and a tool that I wrote that accepts text file input and drives the I2C bus. I roughed out a minimal initialization sequence for one of the driver chips and got fairly close. It took a couple of hours of experimentation to get the first LED to turn on. Then I progressed to controlling multiple rows and columns and getting the green controller operating. The red and green LEDs look yellow when both are lit.
In order to generate the data for actual characters, I wrote a tool in Labview to take LED on/off data from a GUI and output it as a .csv file formatted for the LED ON/OFF registers on the IS32FL3738 chip. Labview is a good tool to generate GUI interfaces quickly for me. The bit manipulation and data handling capabilities adequate for this type of work.
The IS32FL3738 chips support a 6x8 matrix, but I am only using a 5x8 matrix. I included the extra column and data in the output for completeness. The tool supports reading an existing data file for editing. Click on a dot...
LiteOn_LTP2558AA_Module_R1p1.pdf
Schematic for LiteOn LTP2558AA test module. Uses 2 IS32FL3738 chips. Has on-board address translation.
Adobe Portable Document Format - 241.67 kB - 08/03/2020 at 19:13
Preview
Bill of Materials-Display1.csv
Bill of Materials for LiteOn LTP2558AA test module. Uses 2 IS32FL3738 chips. Has onboard address translation.
Comma-Separated Values - 1.52 kB - 08/03/2020 at 19:12
Download
LiteOn_Matrix.pdf
Schematic for LTP2558AA Driver Board using 1 IS31FL3730 chip
Adobe Portable Document Format - 122.53 kB - 08/28/2020 at 02:17
Preview
Bill of Materials-SingleDriver1.csv
Bill of Materials for LTP2558AA Driver Board using 1 IS31FL3730 chip
Comma-Separated Values - 947.00 bytes - 08/28/2020 at 02:17
Download
LiteOn_Max7221.pdf
Schematic for LTP2558AA Single Color Driver Board using 1 MAX7221 chip
Adobe Portable Document Format - 150.01 kB - 11/20/2020 at 23:40
Preview
View all 6 files
  • More Thoughts on SPI vs I2C Drivers
    Bharbour • 12/24/2020 at 16:18 • 0 comments
    In the previous log, I talked about the system problems with the ISSI driver chips that use an I2C interface with limited (4 devices per bus segment) address choices. Also mentioned are the daisy chain aspects of the SPI interface using the expensive MAX7221 parts. Possible solutions for the limited address choices in the I2C chips are:
       A) Use multiple I2C buses.
       B) Use address translators to break up the I2C bus in to multiple segments.
       C) Use I2C bus multiplexers to break up the I2C bus in to multiple segments.
    Option A works if you only need a few characters displayed, or the MCU that you are using has multiple I2C buses. The SAMD21 parts in the 100 pin packages give you access to up to 6 I2C buses which would drive up to 24 characters of the single driver version of the IS31FL3730 chips. Managing 6 I2C buses and splitting up the outgoing character data would be a hassle in the software part of the project, but could be done.
    Option B, using address translators to break up the I2C bus in to multiple segments. Linear Technology/Analog devices makes some address translator parts that allow you to XOR bits in the address field of an I2C packet on an isolated sub-bus. The parts that I have used are the LTC4316 (single and LTC4317 (dual) multiplexers. This arrangement works pretty well, I used the LTC4316 parts on the IS32FL3738 based driver boards. The advantage with the translater chips is that you get maximum flexibility on the addressing by using them. If you select your addresses carefully, the fact that the bus is segmented downstream is invisible to the bus host.
    There are a couple of problems with them though: cost, build complexity and limiting your configuration options.  The LTC4316 parts cost $3.61 US each, and will allow you to add 4 additional IS31FL3730 based boards. The original IS32FL3738 boards that I built had two of the driver chips and one of the LTC4316 chips per board. This is an expensive board when you need several of them. Later, I built a dedicated bus splitter/translater board that used two of the LTC4317 chips per board to get up to 4 separate bus segments with their own address translation. The LTC4317 chips cost $4.34 US each, and can support up to 8 of the IS31FL3730 based boards per translater chip.
    Both the 4316 and 4317 parts use external resistor dividers to set the bit combinations to XOR with the address fields. There is one divider to set the lower 4 bits of the address and another divider to set the upper 3 bits of the divider. The resistors used in the dividers need to be 1% resistors to have a deterministic mapping with manufacturing tolerances. Each extra sub-bus adds 4 additional resistors to the board design, configuration and assembly time. For manual assembly, keeping all of the resistor values straight and getting them in the correct location adds to the build time of an otherwise low component count board. I wound up writing a C program to generate a table of the resulting address maps with the resistor combinations.
    The data sheets offer specific values for the resistors to select the XOR bits. The values shown are fairly high resistance. I thought about designing the splitter / translater boards to use jumpers to select the resistor values, but was concerned about spreading these high resistance dividers around on a board with jumpers to get configurability. For the first generation of driver boards that each had their own LTC4316 on them, the PCB real estate required to add a  jumper system in a noisy digital environment was prohibitive. The resistor configuration system is not a binary system, so controlling 4 bits of address configuration would require up to 16 jumpers.
    Option C, using I2C bus multiplexers to break up the I2Cbus. Initial searches for I2C bus multiplexer chips showed only expensive parts, and using bus multiplexers requires some software support. I dug around some more, and found some low cost...
  • Yet Another Driver Board to Play With
    Bharbour • 11/20/2020 at 22:43 • 0 comments
    Speaking with someone here on Hackaday, they mentioned that they were planning on using a Maxim MAX7219 chip for driving these displays. Out of curiosity, I decided to build a few boards to explore this chip. Perusing the data sheet, the MAX7221 looks like an updated version of the 7219.
    Using these parts to drive a matrix LED is a little bit of an "off label" use. The data sheet talks about using these parts to drive up to 8 of the seven segment numeric displays, and not much about driving a matrix display. There is even a BCD to seven segment translator built in to the chips. On further reading, the translator can be bypassed, and the chip is designed to drive common cathode displays. The LTP2558 matrix displays that I have are common cathode displays.
    These chips use SPI for communications instead of the I2C that the other two driver chips use.
    With the I2C based chips, the target address specifies which chip on the bus that you are talking with. The ISSI chips that I used only support 4 different addresses, meaning that if you want more than 4 characters in the display, you have to break up the I2C bus. Address translators or bus mux chips are the two most obvious ways to do this. Either is expensive. Another method would be to use a controller with multiple I2C buses. This seems wasteful of resources, and adds cost, as you need to buy a higher pin count processor.
    The SPI interface uses daisy chaining to build a bus up, and the physical order that you put the data on the bus determines which driver chip winds up with a particular word of data. As a result, there are no addressing limitations created by the SPI interface. There are some limits to how many devices can be put on a chain. There may be timing limitations since all the parts use the same chip select and clock signals to pass and store data. There are bus loading limitations, as it is necesary to drive the clock input and chip select input of every driver chip on the chain. Because of the higher data rates supported by SPI interfaces, expect to have to terminate the SPI bus to preserve signal integrity.
    The biggest advantage that the MAX7219 or 7221 chips bring to the hobby world is that they are available in the old school DIP package, a 24 pin skinny DIP with 0.1" (2.54mm) lead pitch and 0.3" (7.62mm) spacing. These packages are very easy to solder without microscopes or other special tools and skills. They are also small enough to pack two of them on a board that sits on the back of the LTP2558 displays.
    The biggest problem with these chips is that they are expensive. The 7219 chip lists at $8.91US and the 7221 chip lists at $9.26US in single quantities. The pricing does not fall very fast on the volume curve. Searching the net, some sites are offering the MAX7219 as cheaply as $1, but if it sounds too good to be true, it probably is.
    Writing a driver for these chips is somewhat different than the I2C interfaced chips. With the I2C chips, you could write all of the On/Off control registers of one driver chip in a single I2C transaction. With the SPI interface, you can write one of the control registers of each chip on the chain in a single transaction, necessitating breaking up setting the LEDs into a transaction per display column. After some testing, you HAVE to write each chip in the chain every transaction or strange things happen and downstream characters get corrupted.
    Both the I2C and the SPI device drivers use a character generator table to map the incoming ASCII character to the desired pattern of LEDs. The character generator table used for the MAX parts is identical to one of the ones used in the ISSI31FL3730 driver that I already have written. The MAX parts run 5 columns X 8 rows of LEDs in the matrix. The character generator table supports 96 different characters, one for each of the printable ASCII characters. A 2 dimensional array with 96 x 5 bytes holds the character generator table data. When the ASCII data array comes into...
  • Ported the driver code over to the Single Driver display modules
    Bharbour • 09/26/2020 at 21:56 • 0 comments
    Most of the work on the #GPS Driven Clock project is done. It is presented as a separate project.
    As mentioned in earlier log files, the dual driver display modules were too expensive, so I developed driver board using a different driver chip (ISSI IS31FL3730) that is about 40% of the cost of the dual driver modules. When I started on the clock project, I had just gotten the first of the single driver modules built up and minimally tested.
    This morning, I built up the other two PCBs for a total of 3 of these displays operating. In order to drive the new displays with more than just test code, I ported the software drivers over to deal with the IS31FL3730 chip. The architecture of the new chip is quite a bit simpler than the previous one, so the initialization sequence changed and there is only one chip per module to drive. Because of the way that the display had to connect to the driver chip, the data format for the green LEDs is rotated 90 degrees from the format for the red LED data. I brute forced this with a second character generator table rather than rotatating the data in real time. The character generator tables are 768 bytes per table, which is not too ugly.
    The current control register on the new chip is a wierd, discontinuous thing, so I need to write the code to map a linear input value to the required register data format. 10/5/2020 The current control function is written and the display drivers are willing to source up to the 70mA listed on the data sheet. They run kind of warm when doing so though.
    The new chips only support 4 different I2C addresses, and I did not put an address translator chip on each board, as the translator chips cost more than 2X the cost of the display driver chips. I have a bus splitter/address translator board laid out already that will let me run 4 separate bus segments with their addresses mapped to unique spaces, so one of those boards will support up to 16 display modules. Also, the power for the displays and the power for the address translator chips are supplied through different connectors on the splitter translator board. This will allow me to run the I2C bus on the microcontroller side at 3.3V and the individual I2C buses to the displays at 5V which should give more headroom on the LED supply from driver chips.
    10/8/2020 The boards for the I2C Splitter/Address Translator are back. I built the first one up and verified that it is operating as expected. I need to order some more connectors to finish it. Also, it won't be required until I build up more of the single driver displays.
  • The Boards Are Back
    Bharbour • 08/27/2020 at 12:39 • 0 comments
    The last 3 of the rev 1.1 boards are back from OSH Park and assembled. The chassis that I designed for 9 displays is now populated and looks good.
    Fully Populated Display Panel
    I started working on the application code for using these beasts while I was waiting for the boards to come back. It will be a GPS driven clock. I also built a breakout board for an ambient light sensor chip to use for automatically dimming the clock.
    In the previous log file, I mentioned doing a PCB for a different driver chip that would be a less expensive board. After totalling the costs on the bill of materials, the new boards come out at about 40% of the cost of the rev 1.1 boards.
    The new PCB design is a 2 layer board because there is a lot less routing with a single chip than 3 chips, and the heat sinking did not appear to be the problem I was expecting on the original design. Using only 2 layers reduced the cost of the PCB by 50% . A single jumper wire was needed to route one signal on 2 layers, so that one blue wire is a feature, not a mistake :)
    Prototype boards for the new design came back from OSH Park and assembled easily enough. I took care of several convenience issues with the new design like having jumper selectable address and terminator enable. To keep size down on the jumpers, I used the 1.27mm header and shunt blocks.
    Component Side of New Driver Board Design
    Component side of new driver board design
    Assembled Display Module
    Assembled display module.
    Because of the way the matrices of LEDs are implemented in the LiteOn displays, I had to rotate the matrix of the green LEDs by 90 degrees. The red matrix is wired as a common cathode matrix. If the green matrix had been wired as a common anode matrix, it would have matched the intended configuration of the IS32FL3730 chips, but no joy. The displays have two 5x8 common cathode matrices, one red and one green. I wound up connecting the red matrix in the conventional way and connecting the green matrix with the column driver outputs connected to the LED row inputs and the row driver outputs connected to the LED column inputs. This effectively rotates the green matrix 90 degrees. In use, the time penalty of rotating the character generator matrix 90 degrees while updating the display is probably more of a problem than the space incurred with a second character generator data set, so a second character generator data set with the data already rotated will solve that problem.
    Rotating the matrix also has some implications about current control when multiple LEDs are lit in a single column,  but that needs more testing to see if it will be a problem. I have a home written tool that allows sending I2C write transactions controlled by a simple text file with a lot of flexability. It uses the Total Phase Systems Aardvark to go from USB to I2C, SPI or GPIO. The tool called VarkBlaster is useful for exploring configuration and control of parts like this. I wrote a few scripts that drive the display with varying numbers of LEDs lit per row and per column, and there was no difference visible to me in the LED itensity.
    Using the character generator array that I developed for the rev 1.1 IS32FL3738 based boards, I wrote a tool that translates that into the register bit formats for the two matrices in the IS31FL3730 chips and displayed a couple of characters from each array to sanity check it. So far so good. The character generator arrays form a lookup table mapping ASCII code to register values to display the character. In general, the brightness seems a little low but I have not started experimenting with the LED current control register yet.
  • Rev 1.1 PC Boards are Back
    Bharbour • 08/06/2020 at 17:58 • 0 comments
    The rev 1.1 PC Boards are back from OSH Park. I built up all three of them. They are much quicker to assemble since all of the components are on the top side of the board except the sockets for the LED Matrix.
    Assembled Rev 1.1 Board
    I made sure to keep the bolt pattern and it's relationship to the LED Matrix the same as the rev 1.0 boards so they will both live on a mounting plate and be interchangable with the rev 1.0 boards. I also added resistors to support translating the low nibble of the I2C address that were lacking on the rev 1.0 boards.
    I now have 6 of these boards built and operating, and I want 3 more. Those will be ordered this weekend.
    Display Panel With 6 Modules Installed
    The cost on these modules is higher than I am happy with. Separate driver chips (IS32FL3738) are used, one for red and one for green. There are only 4 options for I2C address selection on these driver chips, so I added an I2C address translator to each board to allow running more than 2 boards on an I2C bus. The PCB is a 4 layer board. I chose to use a 4 layer board to get low impedance ground and power distribution to both display drivers and the address translator. Also, the driver chips have a heat spreader pad under them and I wanted to be able to use a ground plane for heat sinking the drivers.
    Poking around in the projects on Hackaday, I found a project that is very similar to this one: #PIXIE - Chainable, Dual 5*7 Micro-LED Displays! The display driver chip (IS31FL3730) used on that project is capable of driving both the red and green matrices in the display, so I laid out a board to use that chip. These chips also support 4 choices for the I2C address, but only one chip is needed per board, allowing up to 4 displays on an I2C bus segment. I removed the I2C address translator and added jumpers to select the address and enable/disable the I2C terminators. My concerns about heatsinking the driver chip did not seem warranted with the rev 1.0 boards, the drivers only run a few degrees above ambient temperature. With a single driver chip to supply power and ground to, a 2 layer board makes more sense. With the changes listed above, the parts count is less than half of what the current boards are using, and it will go on a 2 layer board. To get the same functionality as the previous boards, either bus multiplexing or address translators are going to have to go into a system somewhere. A prototype board for the new driver is ready to send out to OSH Park.
    The new driver chip handles the two matrices in kind of a strange way. One matrix connects to the driver pins labelled row[8:1} and column[8:1] matching the LED pin designations. This is a common cathode matrix. The second matrix looks to be a common anode matrix, but since both matrices in the LED block are common cathode, I rotated the second matrix, connecting driver rows to LED columns and driver columns to LED rows. It is not clear from the documentation whether the hardware corrects for this in the registers for the second matrix or not. I am just going to have to build one and mess with it. If the hardware does not correct for this, it will be necesary to do the pixel rotation in software.
    It is not clear what the maximum LED current is for the new driver. The electrical specs in the data sheet say that the maximum is 40mA, but in the register set description, there is an option for 75mA. Running 40mA per LED may be enough, but that is another thing to test when the boards get back.
    The IS31FL3730 uses my least favorite package for assembly at home, the QFN leadless package. None the less, it is worth trying. It is not like there is a deadline or anything.
View all 5 project logs
Bharbour wrote 04/03/2022 at 13:24 • point
Thanks!
I looked at the LTL-7100M data sheet and that is kind of a funny configuration. The IS31FL3730 driver chips could drive quite a few of them if you set the matrix up yourself. At $3 each it would get expensive fast though.
Good Luck!
TinLethax wrote 04/03/2022 at 03:10 • point
Off topic a bit, Nice project btw. I have one of LiteOn (Not Matrix) LED bar graph LTL-7100M. These Old LEDs had a quite unique configuration that rarely seen these day. Mine has got 4 segment. each one has Green and Amber LED diode connected in opposite direction (A-C, C-A). I got this thing from Chinese seller though taobao agent for $3 plus shipping. And the thing is that I live in Thailand and back then (2 years before I bought that LED) I didn't know that these LEDs are made in my country and I can't get my hand on them unless I import from USA and/or China.
