// by: Eduardo Zola - 2015 (www.zolalab.com.br) egzola@gmail.com #include <SPI.h> #include <Ethernet.h> #include <ICMPPing.h> byte mac[] = {0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02}; EthernetClient client; #define MAX_IPs 5 IPAddress pingAddrs[MAX_IPs]; int CNT = 0; int ERRORS_COUNT = 0; SOCKET pingSocket = 0; char buffer [256]; ICMPPing ping(pingSocket, (uint16_t)random(0, 255)); void setup() { pinMode(9,OUTPUT); // relay Pin digitalWrite(9,HIGH); Serial.begin(9600); Serial.println("Iniciando..."); delay(2000); pingAddrs[0] = IPAddress(74,125,26,147); // google.com pingAddrs[1] = IPAddress(8,8,8,8); // dns google pingAddrs[2] = IPAddress(200,221,2,45); // uol pingAddrs[3] = IPAddress(23,216,170,96); // microsoft pingAddrs[4] = IPAddress(31,13,73,1); // facebook delay(3000); while(Ethernet.begin(mac)==0) Serial.println("Failed to configure Ethernet using DHCP"); Serial.print("My IP address: "); for (byte thisByte = 0; thisByte < 4; thisByte++) { Serial.print(Ethernet.localIP()[thisByte], DEC); Serial.print("."); } Serial.println(); } void loop() { if(ERRORS_COUNT >= 3) { ERRORS_COUNT = 0; Serial.println("BOOT"); boot(); } if(CNT >= MAX_IPs) CNT = 0; ICMPEchoReply echoReply = ping(pingAddrs[CNT], 4); if(echoReply.status == SUCCESS) { ERRORS_COUNT = 0; sprintf(buffer, "Reply[%d] from: %d.%d.%d.%d: bytes=%d time=%ldms TTL=%d", echoReply.data.seq, echoReply.addr[0], echoReply.addr[1], echoReply.addr[2], echoReply.addr[3], REQ_DATASIZE, millis() - echoReply.data.time, echoReply.ttl); } else { sprintf(buffer, "Echo request failed; %d", echoReply.status); ERRORS_COUNT ++; } Serial.println(buffer); delay(1000); CNT ++; } void boot() { digitalWrite(9,LOW); // desliga o modem, por tanto, o relay deve ser usado em NO, ao inves de NC... ou seja, o relay desligado permite que o router fique ligado. Ao acionar o relay, a energia do router eh cortada. delay(5000); // aguarda 5 segundos com o modem desligado digitalWrite(9,HIGH); delay(60*1000*5); // aguarda 5 minutos para o modem inicializar e reconectar, evitando que a rotina o desligue novamente. }
Eduardo Zola
M.R. Inc
Sagar 001
engineerkid1
Thank you for netBOOT. Your software saved me a LOT of time! Here is a photo of my completed project. https://www.flickr.com/photos/8501971@N07/23231947324
