Way back on Star Trek: First Contact I started using Microengineering Labs PICBASIC PRO compiler. I used PICBASIC to write the code for the Borg suits and the spacesuit lighting in that film... That was 19 years ago, and I still use it for simple projects because it is very fast for me to develop in. Here is the very simple program to operate the lighting here:
'written for PICBASICPRO V3 'author Alan McFarland 'August 16, 2015 'simple program to operate lighting for Harlan's walker 'uses PIC12F1501 DEFINE OSC 16 'define the clock speed so PICBASIC knows OSCCON = $FF 'set speed to 16MHz '****************************************************************************** ' SETUP '****************************************************************************** ADCON1 = %00001111 'port a is all digital IO tape con 3 'output pin to LED tape relay var porta.2 'output port to control relay pwmrate con 20000 'pwm freq faderate con 10 'delay in PWM loop to control duration of rate change level var byte count0 var word begin: high relay 'as soon as the µC wakes up, turn on the relay to latch the power hpwm tape,0, pwmrate pause 250 'let settle trigger: for count0 = 0 to 255 gosub fetch 'read in the sine value from the lookup table hpwm tape,level, pwmrate 'send to hardware PWM & fade up to full pause faderate next for count0 = 1 to 50 'with a 2.3 second nap, this keeps light on for 115 sec NAP 7 ;nap for 2.3 seconds next for count0 = 0 to 255 gosub fetch 'read in the sine value from the lookup table hpwm tape, 255 - level, pwmrate 'reverse the value since we are fading down pause faderate + 20 'make it longer to provide notice that its shutting off next low relay 'this will turn off power to the board END fetch: lookup count0,[0,0,0,0,0,0,0,1,1,1,1,1,2,2,2,2,3,_ 3,3,4,4,4,5,5,6,6,7,7,8,8,9,9,10,11,11,12,13,13,14,15,16,16,_ 17,18,19,20,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,_ 42,43,44,45,46,48,49,50,51,53,54,55,56,58,59,60,62,63,64,66,67,69,70,71,73,_ 74,76,77,79,80,81,83,84,86,87,89,90,92,93,95,96,98,99,101,103,104,106,107,109,110,_ 112,113,115,117,118,120,121,123,124,126,128,_ 128,129,131,132,134,135,137,138,140,142,143,145,146,148,149,151,152,154,156,157,159,160,162,163,165,_ 166,168,169,171,172,174,175,176,178,179,181,182,184,185,186,188,189,191,192,193,195,196,197,199,200,_ 201,202,204,205,206,207,209,210,211,212,213,215,216,217,218,219,220,221,222,223,224,225,226,227,228,_ 229,230,231,232,233,234,235,235,236,237,238,239,239,240,241,242,242,243,244,244,245,246,246,247,247,_ 248,248,249,249,250,250,251,251,251,252,252,252,253,253,253,253,254,254,254,254,254,255,255,255,255,_ 255,255,255], level return
