mqspeak is application for logging data sent at MQTT network to ThingSpeak. It can map multiple topics from multiple brokers to multiple ThingSpeak channels.
Currently, mqspeak is in testing and some features are not implemented yet. You can find source code on my GitHub.
Hello, sorry for delay. I just released mqspeak to pypi repository. So you can install with 'sudo pip3 install mqspeak' command.
Can you provide a step-by-step on how to set up mqspeak (on a Raspberry Pi)? Sorry for the "newbie" question. What directory should it go in, and how should it be started?
