String sent from Windows app to Arduino has the following format:
string arduinoData = "C" + cpuTemp + "c " + cpuLoad + "%|G" + gpuTemp +"c " + gpuLoad + "%|R"+ ramUsed
Sub string selection is made on the arduino.
Send performance data and control media to an arduino micro.
Added a touchscreen to replace buttons and oled. Monitor now looks better to me, also added some rectangles of screen protector to get tactile feedback on where the controls are.
Added tray buttons for auto control of lights, oled screen and windows lock.
Details here: http://imgur.com/a/PSDkR
So code is on test running phase. It still needs exception control :( but it seems to be stable on arduino and windows sides. Project also got new lights sub project.
Since it's mi first windows app I used a lot of this tutorial to understand how to made a sys tray app: http://www.codeproject.com/Articles/290013/Formless-System-Tray-Application
Code to select and send data to a serial port is the first update :D
Investing in the best welding respirator is necessary for every professional, amateur, and hobbyist welder. It is mostly because welding exposes you to a lot of damaging gasses and fumes emitted while welding.
https://weldingtoolsgeek.com/best-welding-respirators/
This very complicated About Desktop Monitor Control. https://weldingtoolsgeek.com/
The App is very nice and informative you guys should see https://gadgetspath.com/
The app seems to be amazing the colors are great amazing work
Hello this is very useful for you guys you guys should visit it.
Great work! I would omit sending the "%" sign though because I know the numbers are in percent and not other units. I can save some bandwidth this way.
Nice resource monitor! You really made this project stand out with the windows side app - awesome work!
Thanks, it's my first windows app and it looks that it's not leaking memory or cpu. Been running it for days now.
This piece is designed to help you understand how stick welders works, what features are in the best stick welder, and a few great choices of machines that are suitable for both professionals and beginners.
