Currently, only one part of the decoder is developped and available. This is a critical part, the innovative algorithm (which linearizes the tree-walking from the recursive definition) which must be connected to the other blocks.
The other blocks are the bit-shuffler/bitfield extractor, and the output filter (which depends on the application).
Of course, the forward and reverse blocks must be designed so this doubles the efforts again !
Let's just look at the decoder: it receives one block of data encoded as a bitstream (with a granularity of 8 bits so blocks are byte-aligned).
The bitstream is examined and words are extracted from the bitstream: from x bits they are zero-extended (usually to 16 bits).
Those words are fed to the tree-walker unit that select which words to bypass or subtract and store for later. In the end, the output words are smaller.
These smaller words, either a difference or a litteral value, are sent to the reconstruction filter.
The encoder is almost the reverse but needs one more step, so this is not a totally symmetric process, and it requires more buffering, one full block must be stored before being sent.
So far the decoder has been tested with manually generated word streams. They can also be copy-pasted from dynamic results of the test page in JavaScript: http://ygdes.com/3r/
The bitstream supports several formats to reduce the impact of incompressible or degenerate incomping data.
In the following, we assume that the input data are N-bits positive numbers, packed in blocks of 2^M.
- A leading zero byte indicates "bypass": just reassemble the words with no alteration. This is for total noise.
- A 0 MSB means that the samples have been encoded in "truncated binary" / "economy code". This is practical if there is noise is amplitude-limited. The first word is an economy-encoded value that is the maximum for the whole block. This still bypasses the tree-walking block but saves some bits.
- A 1 MSB means that tree-walking is used. The first word is the size of the first sum. From there on, the tree-walker will compute all the necessary differences and output proper-sized values. "Zerotree" allows blocks of 0s to use almost no room. In this mode, there is a constant feedback from the treewalker to provide the number of expected bits of the next value to extract (which is a little tricky to schedule).
Yann Guidon / YGDES
