pin^2 is a more versatile breakout board with space for extra components
I felt inspired to make an 0603 version using solder pads that are bit bigger to facilitate hand soldering.
I think 0805 is the most popular in the wide field of surface mount hand soldering but having recently made boards with 0603 components I think it is necessary to stock a board for this smaller size as well.
I have concluded 0402 is a young/near-sighted person's game but don't let that stop you from taking that challenge!
I used the pin^2 0805 board to make a standalone PWM module. I documented it on this link here
Just posted a breakout board for SOT23-6 devices. The breakout board is SIL in design and accommodates pads to place 0805 components across any pair of terminals on the SOT23 IC. So you can pull up your signals, bypass your VCC and GND, etc all one simple board that easily plugs into your breadboard.
Check it out on my tindie page:
https://www.tindie.com/products/analog10/pin2-0805-best-breakout-board-for-sot23-6/
To determine where to place your components, look at the labeled pads below.
So to put a component across pins 1 and 3 of your IC, look for the pair of opposing pads labeled PIN1 and PIN3 (on the left side of the image below).
Thanks for the kind words toby. At the end of next week both 0805 and 0603 versions will be available.
Thank you for the comment and pointing out the broken link. Should be fixed now.
This looks super useful. Don't forget to post an update announcing re-availability on Tindie in July 2017! https://www.tindie.com/products/analog10/pin2-0805-best-breakout-board-for-sot23-6
