Concept to Completion of new CrashSpace sign
Have to have:
Remove disinformation
Post logo
Post Name
-pluses:
display open/closed info
tie into calendar
interactive
Plan everything so that we can use Boom lift only once to finish assembly
Rachel prepped design and cut files for vinyl sign. Rachel & Steve applied graphics to plexi. Steve secured a cherry picker and had installed by his handy assistant and sign is done. BOOM!
Showed up to Crashspace and acrylic for top sign now on site. The first of two decals has been made already. Will update as progress is made.
A bit delayed in posting but result set is this:
Write up a document stating requested budget and how said budget will be used. This budget is going to cover these things for phase 1: 4 pieces of 4" x 6" x 1/8" white acrylic sheets (Source already identified), Two 4" x 6" vinyl sheets with (re-visioned) form of vertical Crashspace sticker design (design being worked on by one member, another member has source identified for vinyl), and rental for a scissor lift that will allow us to change out the signs safely.
Things still to look into: any issues to do with having a scissor lift on public sidewalk (permits and the like), scissor lift company rental (check 1 and 2 day rental as well as transportation options)
That's status on phase 1. lower sign won't be reviewed until phase one is done, and we'll look more into the interactive details then.
This is very impressive to see this project here I am working on office removals wirral website you can visit here to move your office equipment's from one place to another.
