1Step 1
Assemble the circuit, using the prototype PCB from my files or just a standard PCB.
The connections are as follows:
Setup:
Arduino nano
Bluetooth HC-05
Addressable 16 LED`s two rings
NRF Module
Pinout:
Arduino Nano 5V:
D9-->CE NRF
D10-->CSN NRF
D13 (SCK)-->SCK NRF
D11 (MOSI)-->MOSI NRF
D12 (MISO)-->MISO NRF
D3-->IRQ
D6-->NeoPIxel DataIn 1
D7-->NeoPIxel DataIn 2
For power source, i am using a 12V power adapter, connected through a schottky diode to the arduino nano board, in addition to a 5V Step down for the LED rings. With addition of 470 uF for the LED`s 5V.
3D print the STL files and you have a timer clock.
For building the Smart juggling balls look here: https://hackaday.io/project/5466-smart-juggling-balls
