Hackaday.io Hackaday.io
Sign up Log in
Areacpld
AreaCPLD is an affordable cpld development board based on the well known Altera maxV CPLD.
miguelMiguel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
12 followers
  • Description
  • Details
  • Files 0
  • Components 16
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
225
0
12
11
Team (2)
  • miguelMiguel
  • noel-carriquiNoel Carriqui
Join this project's team
  • Project bitbucket
  • Schematic
  • Buy
completed project
hardware
cpld
Related lists
Awesome Projects on Tindie
Hackaday.io projects you can buy in the Tindie maker marketplace
This project was created on 08/29/2015 and last updated 11 years ago.
Description
AreaCPLD is a break out development board based on altera maxV cpld family, which provides low cost and low power consumption compared to other cpld families. The project has been developed using Kicad and it's open hardware under the Creative Commons Attribution 4.0 International license (cc-by-4.0).
The purpose of the board is to make an easy way to introduce people to digital logic design using a cheap development board, it can be programmed using one of the most used Hardware Description Languages like VHDL or Verilog.
So... you may be asking... why to use a CPLD breakout board instead of a more powerful FPGA development board?
1- CPLDs are actually cheaper than FPGA
2- CPLDs dot not need to be reprogrammed on every switch ON as they store the configuration inside it's internal flash memory.
3- CPLDs do not need external devices to work (smaller PCB size).
4- CPLDs, the cheapest way to introduce yourself into your first VHDL or Verilog design.
Components
  • 1 × Altera MaxV 5M80ZT100C5N Altera MaxV 5M80ZT100C5N with 80 Logic elements and 79 IOs. TQFP package.
  • 1 × ATTINY9-TS Microcontroller SOT23-6
  • 1 × USB mini B SMD connector To power the board
  • 11 × 100nF 0805 power supply decoupling capacitors
  • 1 × PIN HEADER 2x5 JTAG programming connector, 2.54mm pitch
View all 16 components
Project Logs
Collapse
  • OSH Stencils Finally Here
    Miguel • 10/16/2015 at 12:08 • 0 comments
    Stencils have finally arrived and here we have a picture after unboxing.
    OSH Stencils
    This is the result after applying some solder paste to the boards using the received stencil and the solder paste spreader.
  • Stencils ordered
    Miguel • 09/10/2015 at 12:11 • 0 comments
    Stencils have been ordered to https://www.oshstencils.com/ we are waiting for them to arrive and start reflowing the pcb boards.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
A dual channel RS232 adapter for my FPGA board. It works @ 3.3V or 5V, and may be it can be useful for others things too...
Project Owner Contributor
Dual channel RS232 adapter
just4funJust4Fun
Official Hackaday Prize Entry
The Tinusaur is a small board with ATtiny85 microcontroller and the minimum components to run properly plus shield headers and a battery
The Tinusaur
neven-boyanovNeven Boyanov
A simple Atmel ISP programmer or experimentation/development platform using a Tiny45/85
Tiny Ruler
xdjackiexdXDjackieXD
The 2016 Hackaday Prize
Single Sided, SIL connector, PTH components version of DigiSpark
SILSpark
danjovicdanjovic
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Areacpld", please tell us the reason.
Send message
Remove Member
