DIY Ring LED Update. Part 2
The DIY LED ring light was sometimes sliding left or right causing the camera lens to be covered.
These hacks Part 1 and Part 2 fix this issue well.
http://www.dailymotion.com/video/x3a3h3f_diy-ring-led-update-part-2
The full LED video lighting I use
LED Video lighting Using step down & boost up Voltage
http://www.dailymotion.com/video/x34jaoo_led-video-lighting-using-step-down-boost-up-voltage_tech
