We Do What We Must
09/05/2015 at 10:16 • 0 commentsBecause we can. I had a 7-segment display left over from the #Talk Ranking Machine, and this really begged to be done. Yes, it's useless, silly, and potentially even dangerous if someone left it in a public place. But it was quite fun to do too.
Both the display and the battery holder are soldered directly to the Pro Mini -- the pinout just happens to match. There is no off switch, you just have to remove the battery. The code looks like this:
const int GND_PINS[] = {8, 12, 13, A2}; const int VCC_PINS[] = {A1, 11, 6, 4, 3, A0, 7, 5}; const unsigned char DIGITS[] = { 0b00111111, 0b00000110, 0b01011011, 0b01001111, 0b01100110, 0b01101101, 0b01111101, 0b00000111, 0b01111111, 0b01101111, }; const int BEEP_PIN = 2; void show7seg(int number) { unsigned char digit; div_t result; for (int d = 0; d < 4; ++d) { result = div(number, 10); digit = DIGITS[result.rem % 10]; number = result.quot; for (int s = 0; s < 8; ++s) { digitalWrite(VCC_PINS[s], digit & (1 << s)); } pinMode(GND_PINS[d], OUTPUT); digitalWrite(GND_PINS[d], LOW); delay(2); pinMode(GND_PINS[d], INPUT); } } void setup() { for (int s = 0; s < 8; ++s) { pinMode(VCC_PINS[s], OUTPUT); } for (int d = 0; d < 4; ++d) { pinMode(GND_PINS[d], INPUT); } pinMode(9, OUTPUT); digitalWrite(9, LOW); pinMode(10, OUTPUT); digitalWrite(10, HIGH); } void loop() { static long int last = 0; static int count = 2400; long int now = millis(); if (now - last > 500) { digitalWrite(10, LOW); } if (now - last > 1000) { count -= 1; if (count % 100 == 99) { count -= 40; } last = now; tone(BEEP_PIN, 1200, 25); digitalWrite(10, HIGH); } show7seg(count); }
And that's pretty much it. I might actually make it a game, by adding several wires that you have to cut, that would either stop the counter or make it go faster or something...
