1Step 1
First, construct a switch for your Raspberry Pi GPIO pins. I generally use MOSFETs for these low-voltage operations, with the gate to a GPIO pin.
2Step 2
Some sprinkler systems have a moisture / rain sensor that open or close a circuit to disable or enable the next scheduled irrigation. Usually if a sensor is not installed, there's a jumper wire to keep the circuit open. Replace the jumper or sensor wires with the open & ground wires on the relay or MOSTFET wired to the Pi. --> DO NOT WIRE THE GPIO PIN TO YOUR SPRINKLER SYSTEM <--. You'll likely frizzle-fry the whole thing. You want to close the circuit, not send any amperage to it. Seriously. Don't move on unless you understand your irrigation system. SERIOUSLY.
3Step 3
If necessary, enable the sensor or disable the sensor bypass on the irrigation controller.
4Step 4
Wire everything to the Raspberry Pi and install the SprinklerSwitch software as instructed at https://github.com/deckerego/SprinklerSwitch
DeckerEgo
