Micropython Flight Controller
A stabilization system for drones using a pyboard, a MPU6050 and a RC receiver
The pyboard has a processor much better than commercial flight controllers, so we can made a flight controller similar or better written in python.
The main.py is based is this link:
http://owenson.me/build-your-own-quadcopter-autopilot/
The mpu6050.py is a modified version from here:
https://github.com/cTn-dev/PyComms/tree/master/MPU6050
The pid.py is based from here:
https://github.com/diydrones/ardupilot
To receive the PWM from the RC receiver, I took the code from here:
http://wiki.micropython.org/platforms/boards/pyboard/modpyb/Timer-Examples
To control the speed controls, I take the code from here:
Here is the code: https://github.com/wagnerc4/flight_controller
  • 1 × pyboard micropython board
  • 1 × FrSky receiver 2.4 GHz receiver with telemetry
  • 1 × FrSky transmiter 2.4 GHz transmiter with telemetry
  • 1 × mpu6050 3-axis accelerometer and 3-axis gyroscope
View all 3 project logs
wind wrote 02/21/2024 at 16:51 • point
Finally found this
tabshi wrote 11/16/2016 at 06:54 • point
how about the robust?
wagner wrote 09/12/2015 at 14:42 • point
The pyboard build-in accelerometer only have accelerometer.... The mpu6050 have gyroscope and accelerometer.   In the main.py are commented the code for use the build-in accelerometer:
#accel = pyb.Accel()
imu = MPU6050()
#x, y, z = accel.filtered_xyz()
x, y, z = imu.get_xyz()
You only have to switch this commented lines.
The problem with the built-in accelerometer is that when you shake, it throw wrong data... I have checked the accelerometer documentation and it can determine shake movements, but this feature seems not implemented in the micropython pyboard.
http://micropython.org/resources/datasheets/MMA7660FC.pdf
The mpu6050 doesn't have problems with shake movements....
deʃhipu wrote 09/12/2015 at 09:34 • point
But wait, doesn't pyboard have a build-in accelerometer already?
