Thane modelling our first pot of cold brew
04/14/2016 at 08:44 • 0 comments -
Wooden frame built
04/12/2016 at 08:17 • 0 commentsComponents list now also includes wooden frame pieces. We built a quick frame from MDF, although we are thinking about a laser cut acrylic frame for Version 2.
The frame creates a series of stacked boxes which houses the glassware perfectly. Marking this project as done for now, while we enjoy our first batch of cold brew coffee!
Glassware has arrived
10/09/2015 at 09:58 • 0 commentsAfter ordering a custom beaker and some flasks, they have finally arrived!
Flat bottomed flask (2000ml) for catching the coffee after the drip system
A round bottomed flask (2000ml) for holding the ice, plus a stopper valve (full assembly) for letting the melted ice drip at a constant rate into the beaker.
Custom designed beaker (1000ml) with clamp and drainage hole at the bottom. The grounds will go into this beaker and the water will drip through slowly to the flat bottomed flask.
The old coffee machine looking on as we place the retort stand that will hold the cold brew equipment. Stand has a very heavy base and is solid in order to hold all the kit!
