main frame of the lathe is a old construction level. I bit banged up but it was originally machined on all faces. a bit of hand scraping and polishing with a diamond stone of the faces has left a baby smooth surface. the headstock is built out of a harbor freight 18v cordless drill. I chose this particular model because it has quite precise bearings/ keyed chuck. most of the machine if built from hardened maple. I was against using wood, but all the tests I have done show it to suite my needs rather well
charliex
jupdyke
dekutree64
