just finished jb welding the bearing assembly to the base, all clamped solid and waiting to dry. the traveling bed(idk the technical term) is almost complete. all holes drilled and tapped where need be. for being all wood it is pretty sweet. almost no friction. made sure to make the vertical slides ajdustable. getting ready to mock up the leadscrew
