A few years ago I was joking with a friend that I would love to have my own traffic light. Well a few months went by, and while moving into my new apartment I looked behind some boxes and there was a old dirty traffic light. Turns out my friend got his hands on one, and hid it in my house. I think I am one of very few people who would who would be excited over this.
Well It took two years but it is finally finished. I was living in an apartment when I got the light, and had to wait to get access to all the tools I wanted.
Components
1×
Traffic Light
These are kinda hard to come by, but if you keep an eye out you can find them
Now that the light was cleaned and repainted it was time to put it back together and mount it. I didn't do much with the light for about 6 months. I was working on buying a house, so I waited until I got moved in and settled. I got it mounted on the wall fairly quickly because I was tripping over the dang thing so often. I ordered some special brackets that are made to mount it on the wall like this.
I also punched a whole in the wall and ran the power cable down through the bracket an into the wall, then down to the basement. I also ran an Cat 5 cable through it. Originally I was planning on running this off a rasberry pi, but later I started playing with the Electric Imp.
Power comes in to the terminal block and then is split up. I put in an outlet with a light switch. So I have one outlet inside the bottom box. The light switch cuts all the power to the lights. This way I can turn it off while watching a movie or something like that. The outlet lets me plug in a usb charger. I used one of the thin ones to make sure that the box could close.
The middle box has the Electric Imp and the SainSmart relay board.
There really is not anything too complex about this project. I just took my time to keep it nice and clean. The electric imp runs a program to cycle through the lights. But you can force it any of the lights for a while. You can also send it a command to turn the lights all on, or all off. You can also flash the light a set amount of times. I shared this with my friends so they could send it commands from anywhere. Now they use it to try and get my attention to log in and play some video games with them.
As soon as I added the command to send it a number of times to flash, I had to go back put an upper limit on the number of flashes. My friends were quick to realize that they could send it any number they wanted (which turned out to be a very large number) haha. Now any number over a 100 defaults back to 100.
I was really lucky to get my hands on this old traffic light. I started by taking it all apart and washing off as much of the dirt and grim as I could. If you are lucky enough to get your hands on one, don't expect it to be clean.
Next I sand blasted the whole thing. The traffic light is made of aluminum, so you gotta be careful when sand blasting it. Use low pressure and avoid really aggressive sand.
Then I powder coated it. I did some research and the color is called "school bus yellow." This was my first powder coating project so I really took my time and did two coats. The light will always be inside, so I decided not to do a clear coat.
It is funny that while the powder coat is hot it looks more orange. When I opened up the oven and took the part out, I was really worried it was gonna be orange. But after it cooled down it looked awesome. For being the very first thing I ever powder coated I think it came out great.
You're thinking too much about lighting technology. A standard 15w incandescent bulb would probably be perfect. If you're looking for a bit more light (and need many on/off cycles) this is roughly half as bright as what would be standard: https://www.1000bulbs.com/product/54174/IN-0069A21TS.html
I don't think I over thought it. I put a regular light bulb in my light and thought: 'wow that is too bright.' Then I went to the store and got the least bright light bulb they sold. lol
I had the same problem with how bright the light was. I had regular incandescents in it and couldn't walk into the room with the light on. But I went to the store and found the lowest watt light bulb I could. But now they have these low watt light bulbs so you have to be careful. The ones I have in it now are 40 watt equivalent bulbs. But they actually use like 17 watts. They are still super bright.
I did the exact same thing with a traffic light that I found, and even used the same relay board. I stuck a Raspberry Pi in mine and put Nagios on it and use it to monitor performance on a website at work. The incandescents were so damn hot that I replaced them with LEDs, but now they're so bright that I don't turn it on very much. I was thinking about tint on the front of the lights to dim it a bit, but haven't gotten around to it.
