Address Mux/Decoder Completed
A project log for ED-64: A discrete 8-bit computer
ED-64 will be an 8-bit computer built with discrete components, and will feature a ferrite core memory (documented as a separate project).
andrew-starrAndrew Starr • 05/24/2017 at 09:13•2 Comments
See it cycling through the address space:
The bottom section multiplexes between 2 address sources: the address register and a manually-set address. The top section turns the selected address (blue lights) into a row/column selection for the memory (top right yellow lights).
I need some power splitter/extender cables before I can connect it to the FC memory, that's a project for this weekend.
Next panel: the address register itself.
Ted Yapo wrote 05/25/2017 at 00:22 • point
Well done!
It's nice to see that the build quality matches the concept.
I'm going to put the video on loop and "RELAXEN UND WATSCHEN DER BLINKENLICHTEN"
Andrew Starr wrote 05/25/2017 at 09:01 • point
Thanks Ted :) Plenty more blinkenlichten to come!
