Address Register Installed
A project log for ED-64: A discrete 8-bit computer
ED-64 will be an 8-bit computer built with discrete components, and will feature a ferrite core memory (documented as a separate project).
andrew-starrAndrew Starr • 06/08/2017 at 09:40•1 Comment
The Address Register panel has been installed:
The Address Register latches a 6-bit address from either the FC memory or the Program Counter. The output of the Address Register goes to the Address Mux/Decoder installed previously. Here's a short video of them working together:
Next up: the Program Counter
Yann Guidon / YGDES wrote 06/08/2017 at 11:25 • point
meow......
