1Program
- No external circuit is required for this Project.
- Download the project code here.
- Open the projects using Workshop 4. This project uses the Visi Environment.
- You can modify the properties of each widgets and buttons.
2Compile and Upload
- Click on the “Compile” button.
Note: This step could be skipped. However, compiling is essential for debugging purposes. - Connect the display to the PC. Make sure that you are connected to the right port. Red Button indicates that the device is not connected, Blue Button indicates that the device is connected to the right port.
- Go back to “Home” tab. This time, click on the “Comp’nLoad” button.
- Workshop 4 IDE will prompt you to select a drive to copy the image files to a uSD Card. After selecting the correct drive, click OK.
3Mount uSD Card
- When the uSD card is not yet inserted, this message will appear on your gen4 Display: "Drive not mounted"
- After inserting your uSD card the GUI will be loaaded on your display.
