import os, sys
import pygame, time
import RPi.GPIO as GPIO
from pygame.locals import *
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
temp_sensor = '/sys/bus/w1/devices/28-000006f0ac17/w1_slave'
GPIO.setmode(GPIO.BCM)
GPIO.setup(23,GPIO.OUT)
GPIO.output(23,GPIO.LOW)
def load_image(name, colorkey=None):
fullname = os.path.join('data', name)
try:
image = pygame.image.load(fullname).convert_alpha()
except pygame.error, message:
print 'Cannot load image:', name
raise SystemExit, message
if colorkey is not None:
if colorkey is -1:
colorkey = image.get_at((0,0))
image.set_colorkey(colorkey, RLEACCEL)
return image, image.get_rect()
def write_log(rn):
lfile = open('therm.log','a')
lfile.write(rn)
lfile.close()
def temp_raw():
f = open(temp_sensor,'r')
lines = f.readlines()
f.close()
return lines
def read_temp():
lines = temp_raw()
while lines[0].strip()[-3:] != 'YES':
time.sleep(0.1)
lines = temp_raw()
temp_output = lines[1].find('t=')
if temp_output != -1:
temp_string = lines[1].strip()[temp_output+2:]
temp_c = float(temp_string) / 1000.0
temp_f = int(round(temp_c * 9.0 / 5.0 + 32.0))
return temp_c, temp_f
def adjust_readout(current_temp, desired_temp, tcolor, ccolor, draw_circle):
if draw_circle == True:
circle_temp_font = pygame.font.Font(None, 30)
circle_temp_text = circle_temp_font.render(str(desired_temp), 1, tcolor)
current_temp_font = pygame.font.Font(None, 18)
current_temp_msg = current_temp_font.render("CURRENT",1,tcolor)
main_temp_font = pygame.font.Font(None, 130)
main_temp_text = main_temp_font.render(str(current_temp).strip(' '), 1, tcolor)
background.fill(( 0, 0, 0))
screen.blit(background, (0,0))
textx = main_temp_text.get_rect(centerx=background.get_width()/2)
texty = main_temp_text.get_rect(centery=background.get_height()/2)
screen.blit(main_temp_text, (textx[0],texty[1]))
screen.blit(circle_temp_text,(400,30))
screen.blit(current_temp_msg,(210,198))
pygame.draw.circle(screen,ccolor,(411,41),20,1)
allsprites.draw(screen)
pygame.display.update()
def alt_display(temperature):
d = time.strftime('%l:%M%p %z on %b %d, %Y')
t = str(d[0:5].strip(' '))
dt = str(d[17:23].strip(' '))
font1 = pygame.font.Font(None, 72)
text1 = font1.render(t, 1, (0, 0, 250))
textx = text1.get_rect(centerx=background.get_width()/2)
texty = text1.get_rect(centery=background.get_height()/2)
screen.blit(text1, (textx[0],texty[1]-5))
font2 = pygame.font.Font(None, 40)
text2 = font2.render(dt, 1, (0, 0, 250))
textx = text2.get_rect(centerx=background.get_width()/2)
texty = text2.get_rect(centery=background.get_height()/2)
screen.blit(text2, (textx[0],texty[1]+32))
font3 = pygame.font.Font(None, 50)
text3 = font2.render(str(temperature).strip(' '), 1, (0, 0, 250))
textx = text3.get_rect(centerx=background.get_width()/2)
texty = text3.get_rect(centery=background.get_height()/2)
screen.blit(text3, (textx[0],texty[1]-50))
class InnerCircle(pygame.sprite.Sprite):
def __init__(self):
pygame.sprite.Sprite.__init__(self)
self.image, self.rect = load_image('c0.png', -1)
screen = pygame.display.get_surface()
self.area = screen.get_rect()
self.rect.center = (self.area[2]/2, self.area[3]/2)
self.rot = 0
self.original = self.image
def once(self):
center = self.rect.center
self.rect = self.image.get_rect(center=center)
def spinl(self):
self.rot -= 4
rotate = pygame.transform.rotate
self.image = rotate(self.original, self.rot)
def spinr(self):
self.rot += 4
class OuterCircle(pygame.sprite.Sprite):
def __init__(self):
self.image, self.rect = load_image('c1.png', -1)
self.rot = 0
def once(self):
def spinl(self):
self.rot -= 4
def spinr(self):
self.rot += 4
class TickCircle(pygame.sprite.Sprite):
def __init__(self):
self.image, self.rect = load_image('c2.png', -1)
self.rot = 0
def once(self):
def spinl(self):
self.rot -= 4
def spinr(self):
self.rot += 4
pygame.init()
current_temp = 0
desired_temp = 0
pygame.mouse.set_visible(False)
running = 1
changed = False
counter = 0
heaton = 0
old_temp = 0
desired_temp = read_temp()[1]
current_temp = desired_temp
screen = pygame.display.set_mode((480, 320), pygame.FULLSCREEN)
innercircle = InnerCircle()
outercircle = OuterCircle()
tickcircle = TickCircle()
allsprites = pygame.sprite.RenderPlain((innercircle, outercircle, tickcircle))
os.putenv('SDL_FBDEV', '/dev/fb1')
os.putenv('SDL_MOUSEDRV', 'TSLIB')
os.putenv('SDL_MOUSEDEV', '/dev/input/touchscreen')
pygame.time.set_timer(USEREVENT + 1, 10000)
innercircle.once()
outercircle.once()
tickcircle.once()
background = pygame.Surface(screen.get_size())
background = background.convert()
text = font.render(str(current_temp), 1, (0, 0, 250))
textx = text.get_rect(centerx=background.get_width()/2)
texty = text.get_rect(centery=background.get_height()/2)
screen.blit(text, (textx[0],texty[1]))
while running:
for event in pygame.event.get():
if event.type == QUIT:
running = 0
elif event.type == KEYDOWN and event.key == K_ESCAPE:
running = 0
if event.type == KEYDOWN and event.key == K_a:
desired_temp -= 1
for num in range(1,8):
innercircle.spinr()
outercircle.spinl()
screen.blit(background, (0, 0))
adjust_readout(current_temp, desired_temp, (0,0,255),(0,0,255),True)
if event.type == KEYDOWN and event.key == K_s:
desired_temp += 1
innercircle.spinl()
outercircle.spinr()
adjust_readout(current_temp, desired_temp, (255,0,0),(255,0,0),True)
if (event.type is MOUSEBUTTONDOWN):
pos = pygame.mouse.get_pos()
if pos[0] > 160 and pos[0] < 320:
print "Middle tap", pos
adjust_readout(current_temp,desired_temp,(0,0,255),(0,0,255), False)
if pos[0] > 320:
changed = True
desired_temp += 1
innercircle.spinl()
outercircle.spinr()
if pos[0] < 160:
changed = True
desired_temp -= 1
innercircle.spinr()
outercircle.spinl()
if event.type == (USEREVENT + 1):
print "Check Temperature"
print "Desired Temperature: " + str(desired_temp)
print "Actual Temperature: " + str(read_temp()[1])
print "Burner: ",heaton
rn = str(time.strftime('%l:%M%p %z on %b %d, %Y'))
current_temp = read_temp()[1]
if current_temp != desired_temp:
print "Something Changed"
changed = True
if desired_temp > current_temp:
adjust_readout(current_temp, desired_temp, (0,0,255),(255,0,0),True)
if heaton == 0:
GPIO.output(23,GPIO.HIGH)
rn = rn + " Current temperature:"+str(current_temp)+" Desired temperature:"+str(desired_temp)+" Heat ON\n"
write_log(rn)
heaton = 1
if desired_temp < current_temp:
if heaton == 1:
rn = rn + " Current temperature:"+str(current_temp)+" Desired temperature:"+str(desired_temp)+" Heat OFF\n"
write_log(rn)
heaton = 0
if desired_temp == current_temp:
if changed == True:
rn = rn + " Current temperature:"+str(current_temp)+" Desired temperature:"+str(desired_temp)+" Equality - Heat OFF\n"
write_log(rn)
heaton = 0
changed = False
counter += 1
if counter < 5:
alt_display(current_temp)
print counter
else:
counter = 0
print counter
