Added new 180º designs
06/12/2017 at 21:59 • 0 commentsI uploaded two new 180º NeoJoint designs. One has a 20mm spacing (so LEDs are spaced out) and a 10mm one (where the strips are touching). Below is the 10mm pitch one.
Added 60º and 120º angles
03/15/2017 at 19:45 • 0 commentsTwo more angles added:
- 60º: good for making triangles
- 120º: good for making hexagons
Demo using blink(1) mk2
03/15/2017 at 19:42 • 0 commentsHere's a quick demo video showing a square made with NeoJoints and WS2812 strip and a blink(1) mk2 to control them
"How to solder" instructions
03/04/2017 at 19:39 • 0 commentsI put up some quick "how to solder" NeoJoints. The technique I show is the fastest and most reliable I've found so far as I've been developing these.
Check them out here: https://github.com/todbot/NeoJoints#how-to-solder
Sharp tools make all the difference
02/27/2017 at 22:44 • 0 commentsWhat a difference sharp tools make! Same piece, same @Othermill setup, just swapped endmill, no post-process.
New repo; New versions of NeoJoints
02/27/2017 at 22:41 • 0 commentsI've been re-laying out some of the joints as "NeoJointsV2".
You can check them out in the new NeoJoints repo:
I'm playing around with putting the screw hole in the center of the rotation point of the joint:
