What?? An automated Chicken Coop
Got my KPS-5-1 power supply installed today! Along with the Buck Converter and Boost Converter.
The KPS-5-1 takes 24v(AC) in and 12v(DC) from a battery and out puts 13.8v DC. The Buck Converter drops 13.8 down to 5v to power the rPi, Driver board and relay board. The Boost Converter raises 13.8v to 30v to power the actuator. The KPS-5-1 has an LED to show AC power status (LED illuminates with AC power off when powered by battery). So.. I swapped the LED with an optocoupler and wired the output to GPIO 25. Next I will write a script that checks GPIO 25 for high every 5 minutes and then install it as a service. If GPIO 25 goes low we know that power failed so the script will shutdown the automation service and open the door, after GPIO 25 goes high again it will check it for 10 minutes and then restart the automation service again.
I get my new power supply Thursday at which point I'll mount everything and post a new pic.
I shouldnt be using GPIO 7 and 8 for outputs. Its a chicken coop. I'll write a startup script that changes their mode to out at start up.
COMING SOON!
There are limit switches built into the actuator, but they do not give any external feed back. The switches simply shut off the motor when the actuator has reached its limits. Which is helpful since its easier to code always on than run once. I do have plans to put in reed switches in to detect open/close failures. I love the power of the Pi in such a small form factor.
That's a pretty serious actuator! Any concerns with squishing absent-minded chickens, or is it too slow for that?
It is! I live in Minnesota so Ice clogging the door may be a problem, I wanted an actuator that would be able to break through any ice in the track. I've thought adding a light barrier to ensure that a hen doesn't prematurely become chicken dinner. Alas, I think that the senor would catch far too many false positives (chickens are dusty, messy animals). The door closes very slowly at the rated 24 volts; it closes and opens in about 60 seconds.
MPLS REPRESENT! I'm in NE, you?
Yeah, I took a look at the actuator spec and it says something like 5-6 mm/sec. Seems totally reasonable. Is this your first MN winter w/ chickens? It's something my wife and I have been considering, but we haven't quite gotten that far..
LOL, Corcoran!
It is our first winter with them yes, they were born late winter last year and did not come out until the spring. They are well worth the effort theres nothing like fresh eggs! We have 14 and they started laying about a month ago we get 5-8 eggs a day as of now, in a month or so we expect 12-14 per day.
Do you have limit switches to detect the door status? I used an old window mechanism for a car on our chicken coop, with a top & bottom microswitch. It had a time limit for the motor to run in case something went wrong (it did, frequently). I really must get round to getting an Rpi fitted instead of the Arduino.
