If you'd like to enter, please post a link to your project's page as a comment on this project log!
Some reminders:
You don't need to have your PCB's schematics or circuit design finished to enter.
Each user can enter up to 10 PCBs. [One PCB per project.]
Your PCB can be smaller than 1x1".
Entered projects are listed here:
https://hackaday.io/list/7909-square-inch-project-entrants
My apple of eye. Is "Eyeduino" a better name? :) Just 18mm x 18mm!
https://hackaday.io/project/7989-pointduino-mini
Beautiful! One small tip: It would look even better if all the vias would be hidden under the µc...
Another of my idle musings:
https://hackaday.io/project/6335-wedding-led-doodads
The doodaddery is strong with this one.
I've added it :)
https://hackaday.io/project/4819-simple-electronic-compass
I had planned to make it small, but I'll be making it fit the 1"x1". Still in progress.
Good luck—I've added you!
Nothing too fancy but fits in 1x1:
https://hackaday.io/project/4277-stm32f030f4p6-breakout-board
Added!
Oh, uh, thanks. Just saw this log. Ignore my previous request, I'll come up with a project first :-/
Sounds good :)
https://hackaday.io/project/7974-microethernet
Mini Webserver
You're in :)
https://hackaday.io/project/7961-micro-word-clock
Nice, I added you
Thanks!
https://hackaday.io/project/7666-arduinocade
Added!
https://hackaday.io/project/7947-quadcopter-in-one-inch
tiny flying machine
I'll add you. Double-check those pads for the QFP, though!
thanks.
QFN actually. no pins.
Ah, ok—were they okay? they looked quite cramped.
https://hackaday.io/project/7944-at26-chuck
Adapter for playing Atari 2600 with Wii Nunchuck. Let's try a through hole design this time.
https://hackaday.io/project/7941-avercade
Customisable USB adapter for arcade controls based on AVR wit V-USB and USBASPLoader.
https://hackaday.io/project/7932-trackthor
Not one, but 3 boards under 1 inch. Actually one in 26mm long not 25.4 because of the chip dimension. But i can cut easy 0.6 and have the top chip bigger then the actual pcb. So, am i disqualified?
correct, but then what's the fun? that would be 3 pcb's with no individual functionality that can be of interest. They work as whole and that is the fun: 3 pcb's under 1 inch each, can give a fun device within a cube inch of PCB's. :-) Thanks anyway.
https://hackaday.io/project/7921-usbreadboardit
added!
https://hackaday.io/project/7920-dipsy-starter
https://hackaday.io/project/6623-xmod-usb-cpld-kit-or-interface
Hi I would like to submit the Lisa/S UAV autopilot to the contest.
http://wiki.paparazziuav.org/wiki/Lisa/S
It is a 20mm x 20mm (0.619sq/inch) fully autonomy capable autopilot. Even when you add on the 2.4GHz RC control and telemetry module (CyRF) it is still less than an inch of surface area: 0.852sq/inch :)
Here also the link with some better photos:
http://1bitsquared.com/collections/autopilots/products/lisa-s
Piotr,
Could you create a hackaday.io project page for your project so I can add it? Thanks!
Just did that: https://hackaday.io/project/7918-lisas-autopilot
Added you to the list!
This is such a cool contest. Did you create it just for me? I would like to enter my OSHChip_V1.0 project.
https://hackaday.io/project/7212-oshchip-v10
At .350" x .780" it comes in at .273 square inches, so almost 4 copies per square inch. Can I enter 4 times :-)
It is a Cortex-M0 processor, 32K RAM, 256K Flash, assorted peripherals and Bluetooth Low Energy radio (nRF51822) packaged as a 16 pin DIP.
Not my work but what about #DIPSY?
If @antti.lukats wants to enter...
https://hackaday.io/project/6592-dipsy/log/26069-even-smaller
WAAAY TOOO SMAAALL
There's no minimum size.
Check out the Twiz, it's a 1 inch square IMU (9 degree of freedom) that sends data over BlueTooth (Low Energy):
hackaday.io/project/7121-twiz
I've added it!
Thanks ;)
Submitting my entry to this contest - HIZ , a Human/Infected/Zombie multiplayer game inspired by a recent post on the HAD blog.
https://hackaday.io/project/7900-hiz
I'll add you. Just so you know, you can make the board smaller than 1x1".
Then I'll have to change the cr2032 into into a cr1220.... Hmm... yes. maybe that. But the battery lifetime will be severely affected.
But it would be rather cool to fit 9 pcs of the design onto a cheap 5x5cm pcb.
You don't have to! If you would, maybe you could have two stacked? I think I remember some coin cell battery holders that did that. I was just pointing it out since the front had a lot of unused space.
I bought some 'super capacitors' or 'gold capacitors' the other day to replace a button cell. I didn't do the math as to how long a charge would compare because my reasoning was reliability. A one Farad (1F) super capacitor is quite small.
I think you might want to do the math anyways....
If I remember correctly a 1F 2.5 volt capacitor can hold just a bit over 1 Joule of energy. A bog standard CR2032 is about 1000J if discharged carefully.
That is three orders of magnitude in difference!
How are you doing the math? I am using a 5v 1F cap - charging to 3v and then discharging to 2v and I get 277mAH for the capacitor when a button cell like CR2032 is about 225mAH.
I didn't do the math. :-) I just picked rule-of-thumb values out of the top of my head. But let's do the maths and see...
Energy in a cap in Joules is 0.5*C(V2)
So you capacitor charged to 3 volts is holding in total 0.5*1*(3*3)=4.5 J if discharged all the way down to zero volts. You are only discharging down to 2 volts so there will be less.
So let's approximate that by taking the energy at 2 volts in the cap can subtracting that from 4.5J. 0.5*1*(2*2)=2J 4.5J-2J = 2.5 Joules extracted from a 1F cap during discharge from 3 volts down to 2 volts.
Ok, so let's look at the energy in a CR2032. 1 Joule is 1 Watt during 1 Second. As you said a CR2032 is about 225mAh and at 3 volts that will give us 0.225*3=0.675Wh. Multiply this by 3600 to get down to seconds and you'll end up with 0.675*3600=2430 Ws = 2430 Joules.
2.5J vs 2430J is almost exactly three orders of magnitude....
So.... How did you measure the 277mAh for your cap? Are you sure it's not 277 miliamp seconds?
I used coulombs and I am still looking for where I went wrong.
