The fan I used was an unused fan from a BitFenix Shinobi XL Tower computer case:-
BitFenix Spectre™ fans. 230mm diameter
The Boost convert:-
Boost Buck Voltage Module Step Up/Down Converter Regulator 3-35V or 2.2-30V eBay Seller Seller :accecity-ca
The carbon filters Carbon Fibre Oven hood filters, these come in a sheet that may be cut to size, with care you will most likely get two. ( I use a bigger and a smaller filter as a double filter), lots of filters to use:-
Carbon Universal Cooker Hood Filter 47cm x 57cm eBay Seller reliant-cleaning-servicesCardboard Box to fit it all in
Rocker Switch, before the Boost Converter so when turned off no power is used by the Boost Converter
http://www.icstation.com/advanced_search_result.php?keywords=switch+rocker&search_in_description=1
USB Cable and other cables, etc..
Hot Glue
Solder and soldering iron
Heat shrink tube where required
Films4You
Johnny
Nick Sayer
Torbjörn Lindholm
Ryan Aguilar
