Shower curtain fastenings coming loose. A Hack and fix
Quite often the track hooks would come out of the shower curtain track ...
This can happen often and be a nuisance.
The issue is that the bottom gap where the track hooks slide is too wide, by a small amount.
Squeezing the track does not help because there are two sides to the track joined by a rubber type part that just springs the track back as it was reopening the gap again
Require two wooden spring pegs and a ladder to reach
Wooden pegs are use to grip better in the top slot but these may be subjects to mould in such a damp place, anti-mould treatment should help
Daily Motion Video How to
Shower curtain fastenings coming loose Hack and Fix
