New Enigma Z App for the KIM Uno
12/29/2016 at 12:04 • 0 commentsIn addition to this clock program, now there is a new application you can add to your KIM Uno, an Enigma Z Machine Simulator.
Follow the link below to learn more:
https://hackaday.io/project/18644-mystery-6502-program-for-the-kim-uno-1kbchallenge
Project submitted to reddit An Unconventional Clock contest
04/06/2016 at 03:13 • 0 commentsThis project was submitted to a reddit unconventional clock contest. Two entries will win. One will be decided by popular vote, the other one by a panel of judges.
https://www.reddit.com/r/diyelectronics/comments/4dh0x8/voting_thread_beginner_challenge_an/
Adjusting the time delay
09/27/2015 at 21:21 • 0 commentsThe routine from 424 to 42D delays for a second while keeping the display alive by calling the KIM ROM routine to display the value of cells F9,FA,FB on the display. On my KIM, the value of 45 was found to be the best, 46 is too slow, 44 is too fast.
If you need to adjust yours, hold the [RS] key down for more than 1 second until the display flashes, this indicates that the write protection to the EEPROM is off. then enter [AD] 425 [DA] and type your new two digit delay value.
To have a more precise delay, a nested loop containing nops would need to be placed inside the existing loop. This would increase the byte count though.
The time display routine would look like this. To adjust the time, change the LDA $44 and LDA $90 lines. The first one is a coarse and the second a fine adjustment.
LDA #$44 STA *$28 L1 JSR $1F1F LDA #$90 STA *$27 L2 NOP DEC *$27 BNE L2 DEC *$28 BNE L1 JMP START
Program Listing
09/27/2015 at 02:24 • 0 comments* = $0400 0400 START 0400 SED F8 0401 CLC 18 0402 LDX #$00 A2 00 0404 LDA #$01 A9 01 0406 STA *$29 85 29 0408 NEXTD 0408 LDY #$00 A0 00 040A LDA *$29 A5 29 040C ADC *$24,X 75 24 040E STA *$24,X 95 24 0410 CMP CARRYT,X DD 32 04 0413 BEQ CONTIN F0 06 0415 LDY *$24,X B4 24 0417 LDA #$00 A9 00 0419 STA *$29 85 29 041B CONTIN 041B STY *$24,X 94 24 041D STY *$F9,X 94 F9 041F INX E8 0420 CPX #$03 E0 03 0422 BNE NEXTD D0 E4 0424 LDA #$45 A9 45 0426 STA *$28 85 28 0428 L1 0428 JSR $1F1F 20 1F 1F 042B DEC *$28 C6 28 042D BNE L1 D0 F9 042F JMP START 4C 00 04 0432 CARRYT 0432 .BYTE $60 60 0433 .BYTE $60 60 0434 .BYTE $24 24
Arduino Enigma
