Source Code
12/11/2014 at 18:08 • 0 commentshttps://gist.github.com/rockfishon/9ff774cac8dc306963d6/2d7cdfda8622ca834ae21b5ce2a0e1bff0f32264
Code
12/11/2014 at 17:48 • 0 comments// stove ver 110
#include <Adafruit_MAX31855.h>
#include <LiquidCrystal.h>
#include <Servo.h>
#include <PID_v1.h>
// define integers
int x = 0;
int setBeepBuzzer= 1;
int muteBuzzer = LOW;
int overTemp = LOW;
int stoveMode = HIGH;
int stoveShutdown = LOW;
double stoveRunTemp = 500;
int overtempSetPoint = 600;
int servoPos = 15;
int roomTempSetPoint = 72;
int minStoveDamperSetting = 45;
int stoveShutdownSetting = 31;
double fdiff = 0;
double insideTemp = 70;
double f = 0;
int fInt = f;
int cfg = 0;
double Output;
double fnew;
const int pulseWidthMin = 500;
const int pulseWidthMax = 2100;
int stoveRunTempInt = stoveRunTemp;
// define pin constants
const int buttonMutePin = 2;
const int thermoCLK = 3;
const int thermoCS = 4;
const int thermoDO = 5;
const int buttonStoveTempSetPointUp = 6;
const int buttonStoveTempSetPointDown = 18;
const int lcd1 = 7;
const int lcd2 = 8;
const int lcd3 = 9;
const int lcd4 = 10;
const int lcd5 = 11;
const int lcd6 = 12;
const int buzzerPin = 15;
const int servoPin = 14;
const int buttonRoomTempSetPointUp = 16;
const int buttonRoomTempSetPointDown = 17;
Servo myservo;
Adafruit_MAX31855 thermocouple(thermoCLK, thermoCS, thermoDO);
LiquidCrystal lcd(lcd1, lcd2, lcd3, lcd4, lcd5, lcd6);
PID myPID(&f, &Output, &stoveRunTemp, 4, .2, 1, DIRECT);
void setup() {
myservo.attach(servoPin, pulseWidthMin, pulseWidthMax);
pinMode(buzzerPin, OUTPUT);
pinMode(buttonRoomTempSetPointUp, INPUT);
pinMode(buttonRoomTempSetPointDown, INPUT);
pinMode(buttonMutePin, INPUT);
pinMode(buttonStoveTempSetPointUp, INPUT);
pinMode(buttonStoveTempSetPointDown, INPUT);
Serial.begin(9600);
lcd.begin(16, 2);
myservo.write(180);
myPID.SetOutputLimits(minStoveDamperSetting, 180);
myPID.SetMode(AUTOMATIC);
// 1234567890123456
lcd.print("Stove Control 8");
lcd.setCursor(0, 1);
// 1234567890123456
lcd.print("by ROCKFISHON");
// wait for MAX chip to stabilize
delay(1000);
void loop() {
// read thermocouple and subtract internal heat from lcd and interface board
insideTemp = (thermocouple.readInternal() * 9 / 5 + 29);
fnew = thermocouple.readFarenheit();
while (isnan(fnew)) {
lcd.print("T/C Problem");
fdiff = fnew - f;
f = fnew;
fInt = f;
// Compute PID
myPID.Compute();
// Damper control section
// servoPos = 0 then damper is closed
// servoPos = 180 then damper is fully opened
if (!stoveShutdown && f <= insideTemp + 10) { // close the damper if the fire is out
stoveShutdown = HIGH;
if (stoveShutdown && f >= insideTemp +20) { // open the damper when the fire is started
if (insideTemp <= roomTempSetPoint-.25) {
stoveMode = HIGH;
if (insideTemp >= roomTempSetPoint+.25 || overTemp == HIGH) {
stoveMode = LOW;
if (stoveShutdown) {
myservo.write(stoveShutdownSetting);
servoPos = stoveShutdownSetting;
else {
if (stoveMode) {
myservo.write(Output);
servoPos = Output;
else
myservo.write(minStoveDamperSetting);
servoPos = minStoveDamperSetting;
// input loop for 5 seconds
for (int y = 0; y < 50; y++) {
// read mute button
if (muteBuzzer == LOW) {
muteBuzzer = digitalRead(buttonMutePin);
// buzzer overtemp alarm section
if (muteBuzzer) {
if (f < overtempSetPoint) { //resets the mute buzzer variable if the stove temp goes below the set temp
muteBuzzer = LOW;
overTemp = LOW;
digitalWrite(buzzerPin, LOW);
else
if (f > overtempSetPoint) {
digitalWrite(buzzerPin, HIGH);
overTemp = HIGH;
else
overTemp = LOW;
// beep buzzer to remind to close damper
if (setBeepBuzzer == 0 && fInt <=175) {
setBeepBuzzer = 1;
if (setBeepBuzzer ==1 && fInt >=200) {
for (int x = 0; x < 5; x++) {
delay (100);
delay (500);
setBeepBuzzer = 2;
// beep buzzer to remind to close drawer
if (setBeepBuzzer == 2 && fInt >=400) {
delay (100);
delay (500);
setBeepBuzzer = 0;
//Config section
if (digitalRead(buttonRoomTempSetPointUp) && digitalRead(buttonRoomTempSetPointDown)) {
cfg = 1;
lcd.setCursor(0, 0);
lcd.print("minStoveDamperSe");
lcd.print(minStoveDamperSetting);
lcd.print(" ");
delay (1000);
while (cfg == 1) {
while (digitalRead(buttonStoveTempSetPointUp)) {
if (minStoveDamperSetting < 180) {
minStoveDamperSetting = minStoveDamperSetting + 1;
lcd.print(" ");
delay (100);
while (digitalRead(buttonStoveTempSetPointDown)) {
if (minStoveDamperSetting > 0) {
minStoveDamperSetting = minStoveDamperSetting - 1;
lcd.print(" ");
delay (100);
cfg = 2;
lcd.print("stoveShutdownSet");
lcd.print(stoveShutdownSetting);
lcd.print(" ");
delay (1000);
while (cfg == 2) {
if (stoveShutdownSetting < minStoveDamperSetting ) {
stoveShutdownSetting = stoveShutdownSetting + 1;
lcd.print(" ");
delay (100);
if (stoveShutdownSetting > 0) {
stoveShutdownSetting = stoveShutdownSetting - 1;
lcd.print(" ");
delay (100);
cfg = 0;
//Setting the room temperature
while (digitalRead(buttonRoomTempSetPointUp)) {
roomTempSetPoint = roomTempSetPoint + 1;
if (roomTempSetPoint == 81) {
roomTempSetPoint = 80;
lcd.setCursor(13, 1);
lcd.print(roomTempSetPoint);
delay (500);
while (digitalRead(buttonRoomTempSetPointDown)) {
roomTempSetPoint = roomTempSetPoint -1;
if (roomTempSetPoint == 64) {
roomTempSetPoint = 65;
delay (500);
// Setting the stove temperature
stoveRunTemp = stoveRunTemp + 25;
if (stoveRunTemp == 725) {
stoveRunTemp = 700;
overtempSetPoint = 100 + stoveRunTemp;
lcd.print(stoveRunTempInt);
delay (500);
stoveRunTemp = stoveRunTemp - 25;
if (stoveRunTemp == 175) {
stoveRunTemp = 200;
delay (500);
delay (100);
// DISPLAY SECTION
// First Line
// Print stove probe temperature / servo position / stove run temp
lcd.print(fInt);
lcd.print("F ");
lcd.setCursor(5, 0);
lcd.print(servoPos);
lcd.print(" ");
lcd.setCursor(10, 0);
lcd.print(insideTemp);
lcd.print("F");
// Second Line
// print the room temperature set point / over temp setting / room temperature
lcd.print("F ");
lcd.setCursor(5, 1);
lcd.print(fdiff);
lcd.print("F ");
lcd.print("F");
// Serial Output Debugging
Serial.print(f); Serial.print(","); Serial.print(stoveRunTemp); Serial.print(","); Serial.print(overtempSetPoint); Serial.print(","); Serial.print(servoPos); Serial.print(","); Serial.print(fdiff); Serial.print(","); Serial.print(roomTempSetPoint); Serial.print(","); Serial.println(insideTemp);
