For a silly project, this has a lot of experimenting in it. I just figured out how to panelize a board design in Fritzing such that I can send it to DirtyPCBs. I managed to fit 6 nyan cats on a single 5×5cm board, so I should have about 60 of them when the boards arrive.
You can order yours too, if you like: http://dirtypcbs.com/view.php?share=11758&accesskey=87955192e4f12cde5290365bcd4b4c2e
don't they have to be connected somehow?
No idea, I suppose they will contact me if there is a problem.
Hmm, I looked through the DirtyPCBs board shop, and I can see a couple of designs that are disoconnected: http://dirtypcbs.com/view.php?share=1370&accesskey=d58f9c26a725362bf2acb3aec8e8a8f4 http://dirtypcbs.com/view.php?share=1737&accesskey=3af424f619af2140b2cf5f7b95af63c0 http://dirtypcbs.com/view.php?share=5602&accesskey=a53db09db0fe75df7a4a3ae644fdfb96
Please note: only one separate design is allowed in each order. Panelized designs are OK for 2 layer boards only! Separate, non-connected boards will be refused by the board house!
- that's from the about page, I thought I saw something like this...
Argh, ok, fine, I can connect them...
