So I tried the technique described in that link in the previous log, and somehow it didn't work that well for me. I must be doing something wrong, but I didn't understand all details enough to be able to tell what exactly.
But since I already had the ATtiny85 out, I decided to go ahead and make a version of the original code that doesn't rely on the Tone() function (because that function brings about 1500kB of binaries). So instead I just used the good old Timer1.
const unsigned char FREQ[] = {
0, 134, 134, 127, 127, 225, 225, 213, 201, 201, 201, 190, 190, 190, 169,
169, 150, 150,
const unsigned char OCTAVE[] = {
0, 4, 5, 4, 5, 5, 4, 5, 4, 5, 6, 4, 5, 6, 4, 5, 4, 5,
const signed char INTRO_NOTES[] = {
9, 12, -15, -4, 9, 12, 15, 4, 6, 10, 6, 2, -4, -15, 9, 12, -15, -4, 6, 2,
4, 6, 13, 10, 13, 4, 0
const signed char MELODY_NOTES[] = {
-15, -17, 9, 9, 0, 3, 7, 5, 3, 0, -3, -5, -7, 7, 5, 3, 5, 9, 15, 17, 9, 15,
5, 9, 3, 5, 3, -9, -15, 17, 9, 15, 5, 9, 3, 7, 9, 7, 5, 3, 5, -7, 3, 5, 9,
15, 5, 9, 5, 3, -5, -3, -5, -15, -17, 9, 9, 0, 3, 7, 5, 3, 0, -3, -5, -7,
7, 5, 3, 5, 9, 15, 17, 9, 15, 5, 9, 3, 5, 3, -9, -15, 17, 9, 15, 5, 9, 3,
7, 9, 7, 5, 3, 5, -7, 3, 5, 9, 15, 5, 9, 5, 3, -5, -3, -5, -3, 14, 16, -3,
14, 16, 3, 5, 9, 3, 12, 9, 12, 15, -3, -3, 14, 16, 3, 14, 12, 9, 5, 3, 14,
8, 11, 14, -3, 14, 16, -3, 14, 16, 3, 3, 5, 9, 3, 14, 16, 14, -3, 3, 1, 3,
14, 16, 11, 12, 9, 12, 15, -3, -1, -3, 14, 16, -3, 14, 16, 3, 5, 9, 3, 12,
9, 12, 15, -3, -3, 14, 16, 3, 14, 12, 9, 5, 3, 14, 8, 11, 14, -3, 14, 16,
-3, 14, 16, 3, 3, 5, 9, 3, 14, 16, 14, -3, 3, 1, 3, 14, 16, 3, 12, 9, 12,
15, -3, -5
void play(const signed char *notes, const unsigned int length) {
for (int n = 0; n < length; ++n) {
// signed char f = pgm_read_byte_near(notes + n);
signed char note = notes[n];
unsigned char duration, pause;
if (note < 0) {
duration = 220;
pause = 30;
note = -note;
} else {
duration = 110;
pause = 15;
if (note) {
TCCR1 = 1<<CTC1 | (11 - OCTAVE[note]);
OCR1C = FREQ[note] - 1;
delay(duration);
TCCR1 = 1<<CTC1;
delay(pause);
PORTB ^= 1<<3;
void setup() {
DDRB = 1<<4 | 1<<3;
GTCCR |= 1<<COM1B0;
play(INTRO_NOTES, 26);
void loop() {
play(MELODY_NOTES, 216);
I'm still using delay(), because I'm too lazy to setup my own counters for that. Apparently, this is enough:Sketch uses 938 bytes (11%) of program storage space. Maximum is 8,192 bytes. Global variables use 289 bytes (56%) of dynamic memory, leaving 223 bytes for local variables. Maximum is 512 bytes.I will probably work on it some more when I get bored, but the basics are working. Oh, that version is for the 8Mhz internal clock. For the 1Mhz clock, change the 11 to 8.
Just to make sure - isn't your program size 938 + 289 bytes right now?
No, the 289 bytes are RAM.
However, if you put the notes in PROGMEM, you will get:
Sketch uses 942 bytes (11%) of program storage space. Maximum is 8,192 bytes.
Global variables use 45 bytes (8%) of dynamic memory, leaving 467 bytes for local variables. Maximum is 512 bytes.
Which fits in 1kB even counting RAM.
well done then :)
