Boards Ordered
A project log for Nyan Board
A small ATtiny85 board playing the Nyan Cat tune.
dehipudeʃhipu 09/27/2015 at 12:395 Comments
For a silly project, this has a lot of experimenting in it. I just figured out how to panelize a board design in Fritzing such that I can send it to DirtyPCBs. I managed to fit 6 nyan cats on a single 5×5cm board, so I should have about 60 of them when the boards arrive.
You can order yours too, if you like: http://dirtypcbs.com/view.php?share=11758&accesskey=87955192e4f12cde5290365bcd4b4c2e
davedarko wrote 09/27/2015 at 12:42 point
don't they have to be connected somehow?
deʃhipu wrote 09/27/2015 at 12:49 point
No idea, I suppose they will contact me if there is a problem.
davedarko wrote 09/27/2015 at 13:03 point
Please note: only one separate design is allowed in each order. Panelized designs are OK for 2 layer boards only! Separate, non-connected boards will be refused by the board house!
- that's from the about page, I thought I saw something like this...
deʃhipu wrote 09/27/2015 at 14:02 point
Argh, ok, fine, I can connect them...
