Shrunken Cat
A project log for Nyan Board
A small ATtiny85 board playing the Nyan Cat tune.
dehipudeʃhipu 11/24/2016 at 20:594 Comments
So I tried the technique described in that link in the previous log, and somehow it didn't work that well for me. I must be doing something wrong, but I didn't understand all details enough to be able to tell what exactly.
But since I already had the ATtiny85 out, I decided to go ahead and make a version of the original code that doesn't rely on the Tone() function (because that function brings about 1500kB of binaries). So instead I just used the good old Timer1.
const unsigned char FREQ[] = {
    0, 134, 134, 127, 127, 225, 225, 213, 201, 201, 201, 190, 190, 190, 169,
    169, 150, 150,
const unsigned char OCTAVE[] = {
    0, 4, 5, 4, 5, 5, 4, 5, 4, 5, 6, 4, 5, 6, 4, 5, 4, 5,
const signed char INTRO_NOTES[] = {
    9, 12, -15, -4, 9, 12, 15, 4, 6, 10, 6, 2, -4, -15, 9, 12, -15, -4, 6, 2,
    4, 6, 13, 10, 13, 4, 0
const signed char MELODY_NOTES[] = {
    -15, -17, 9, 9, 0, 3, 7, 5, 3, 0, -3, -5, -7, 7, 5, 3, 5, 9, 15, 17, 9, 15,
    5, 9, 3, 5, 3, -9, -15, 17, 9, 15, 5, 9, 3, 7, 9, 7, 5, 3, 5, -7, 3, 5, 9,
    15, 5, 9, 5, 3, -5, -3, -5, -15, -17, 9, 9, 0, 3, 7, 5, 3, 0, -3, -5, -7,
    7, 5, 3, 5, 9, 15, 17, 9, 15, 5, 9, 3, 5, 3, -9, -15, 17, 9, 15, 5, 9, 3,
    7, 9, 7, 5, 3, 5, -7, 3, 5, 9, 15, 5, 9, 5, 3, -5, -3, -5, -3, 14, 16, -3,
    14, 16, 3, 5, 9, 3, 12, 9, 12, 15, -3, -3, 14, 16, 3, 14, 12, 9, 5, 3, 14,
    8, 11, 14, -3, 14, 16, -3, 14, 16, 3, 3, 5, 9, 3, 14, 16, 14, -3, 3, 1, 3,
    14, 16, 11, 12, 9, 12, 15, -3, -1, -3, 14, 16, -3, 14, 16, 3, 5, 9, 3, 12,
    9, 12, 15, -3, -3, 14, 16, 3, 14, 12, 9, 5, 3, 14, 8, 11, 14, -3, 14, 16,
    -3, 14, 16, 3, 3, 5, 9, 3, 14, 16, 14, -3, 3, 1, 3, 14, 16, 3, 12, 9, 12,
    15, -3, -5
void play(const signed char *notes, const unsigned int length) {
    for (int n = 0; n < length; ++n) {
        //    signed char f = pgm_read_byte_near(notes + n);
        signed char note = notes[n];
        unsigned char duration, pause;
        if (note < 0) {
            duration = 220;
            pause = 30;
            note = -note;
        } else {
            duration = 110;
            pause = 15;
        if (note) {
            TCCR1 = 1<<CTC1 | (11 - OCTAVE[note]);
            OCR1C = FREQ[note] - 1;
        delay(duration);
        TCCR1 = 1<<CTC1;
        delay(pause);
        PORTB ^= 1<<3;
void setup() {
    DDRB = 1<<4 | 1<<3;
    GTCCR |= 1<<COM1B0;
    play(INTRO_NOTES, 26);
void loop() {
    play(MELODY_NOTES, 216);
I'm still using delay(), because I'm too lazy to setup my own counters for that. Apparently, this is enough:
Sketch uses 938 bytes (11%) of program storage space. Maximum is 8,192 bytes.
Global variables use 289 bytes (56%) of dynamic memory, leaving 223 bytes for local variables. Maximum is 512 bytes.
I will probably work on it some more when I get bored, but the basics are working. Oh, that version is for the 8Mhz internal clock. For the 1Mhz clock, change the 11 to 8.
Rich text editor
davedarko wrote 11/24/2016 at 21:02 point
Just to make sure - isn't your program size 938 + 289 bytes right now?
deʃhipu wrote 11/24/2016 at 21:05 point
No, the 289 bytes are RAM.
deʃhipu wrote 11/24/2016 at 21:07 point
However, if you put the notes in PROGMEM, you will get:
Sketch uses 942 bytes (11%) of program storage space. Maximum is 8,192 bytes.
Global variables use 45 bytes (8%) of dynamic memory, leaving 467 bytes for local variables. Maximum is 512 bytes.
Which fits in 1kB even counting RAM.
davedarko wrote 11/24/2016 at 21:29 point
well done then :)
