The RepRapXY is a coreXY design RepRap based on Zelogik's machined aluminum coreXY this variant was developed by Jand and sdavi. Jand created the 3D printable version of Zelogik's and sdavi added the modification of horizontal
Zelogik's RepRap.org thread on his machined aluminum + t-slot design
http://forums.reprap.org/read.php?397,297740
Later in the thread you will find Jand and Sdavi's versions
Jand's work
http://forums.reprap.org/read.php?397,297740,page=5
Sdavi's Modifications
http://forums.reprap.org/read.php?397,297740,page=8
All pictures are sdavi's I take no credit for them, they are just the best images around of this printer :)
https://github.com/sdavi/coreXY
The design being built and documented here will comprise of Jand's printable version of Zelogik's design (the RepRapXY) Sdavi's horizontal x axis mod, increase in machine height by 10mm, and printed corner pieces for cosmetics and added rigidity.
Electronics:
Ultimachine Archim: Next Generation 32 Bit RepRap 3D Printer Motherboard
- ATSAM3X8E ARM Cortex M3 MCU (Arduino DUE Compatible)
- x5 DRV8825 Stepper Drivers
- x2 Hotends
- x2 Fans
- Heatbed (15A)
- SD Card
- Expansion Ports
- TinyG2 Motion Control Firmware
AVR
Philip Ian Haasnoot
Elliot
Alex Anderson
Hi, It seems that there are still missing some X-carriage parts: The cable clip and E3D mount. Also, the new Z-axis stuff..
