Ultra small Fully autonomy capable UAV autopilot
can we use this code for mcu of that.is it enough ?
and where is code of radio and gps and...
I can't find your design files. Could you upload them here?
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
That's one tight board! How many layers is it and who manufactured it?
Thanks! :) The board is a 6layer design. I also had to use one set of blind via, to get all signals broken out of the STM32 mcu. The STM32 is in a WLCSP64 0.5mm pitch BGA package.
The code is open source. It is part of the Paparazzi UAV project. There is a reference airframe file that you can find here: https://github.com/paparazzi/paparazzi/blob/master/conf/airframes/examples/ladybird_lisa_s.xml
This also means the code is not a reinvented wheel allowing it to do everything Paparazzi UAV can do for a robotic platform. :) If you know Paparazzi UAV that is quite a lot! :)
The drawing of this board is very good, but I can not find the hardware file, may I ask where is the hardware file, and what software is used to draw the pcb
