Example 1 Video - Step by Step Guide
04/05/2019 at 11:12 • 0 comments -
More Software Examples!
04/05/2019 at 11:08 • 0 commentsAfter you wrote you first program, here are more examples to get you busy!
Example 2:
Make some dancing lights using broadcasted dim Message. Since the dim message enables separate internal timers on each module they end up out-of-sync in a beautiful way :D Note how message parameters with 32-bit size are cast into byte-wide parameters.
You can copy the code below directly into a main.c file in User folder or rename the main_ex2.c file to main.c and replace the older one.
/* FrontEndTask function */ void FrontEndTask(void * argument) { // Random dancing lights #if _module == 1 Delay_ms(500); BOS.response = BOS_RESPONSE_NONE; #endif /* Infinite loop */ for(;;) { #if _module == 1 messageParams[0] = CYAN; // color messageParams[1] = RGB_DIM_UP_DOWN_WAIT; // mode messageParams[2] = (uint8_t)(10000>>24); // period messageParams[3] = (uint8_t)(10000>>16); messageParams[4] = (uint8_t)(10000>>8); messageParams[5] = (uint8_t)(10000); messageParams[6] = (uint8_t)(500>>24); // wait messageParams[7] = (uint8_t)(500>>16); messageParams[8] = (uint8_t)(500>>8); messageParams[9] = (uint8_t)(500); messageParams[10] = 0; // repeat messageParams[111] = 0; messageParams[12] = 0; messageParams[13] = 1; SendMessageToModule(BOS_BROADCAST, CODE_H01R0_DIM, 14); RGB_LED_dim(CYAN, RGB_DIM_UP_DOWN_WAIT, 10000, 500, 1); Delay_ms(500); #endif } }Example 3:
Aroadcast dim (exactly as ex 2) but fully-synchronized. Module 1 emulated the dim functionality and broadcasts color Messages with varying intensity. This way you keep the timer on a single module and keep them all synced. The 500ms delay before the loop is to ensure all modules finished booting before sending first Message.
/* FrontEndTask function */ void FrontEndTask(void * argument) { // Synchronized dancing lights uint8_t i; #if _module == 1 Delay_ms(500); BOS.response = BOS_RESPONSE_NONE; #endif /* Infinite loop */ for(;;) { #if _module == 1 // Up phase for (i=1 ; i<=100 ; i++) { messageParams[0] = 0; // Use color name messageParams[1] = MAGENTA; // color messageParams[2] = i; // intensity SendMessageToModule(BOS_BROADCAST, CODE_H01R0_COLOR, 3); RGB_LED_setColor(MAGENTA, i); Delay_ms(50); } // Down phase for (i=100 ; i>=1 ; i--) { messageParams[0] = 0; // Use color name messageParams[1] = MAGENTA; // color messageParams[2] = i; // intensity SendMessageToModule(BOS_BROADCAST, CODE_H01R0_COLOR, 3); RGB_LED_setColor(MAGENTA, i); Delay_ms(50); } // Off SendMessageToModule(BOS_BROADCAST, CODE_H01R0_OFF, 0); RGB_LED_off(); // Wait Delay_ms(1000); #endif } }Example 4:
Defining a button on Module 1 and enabling its Click event. This event is used to set a flag in the event callback. The flag is used to generate some dancing lights.
/* FrontEndTask function */ void FrontEndTask(void * argument) { // Dancing lights enabled by button on Module 1 BOS.response = BOS_RESPONSE_NONE; #if _module == 1 // Setup the button AddPortButton(MOMENTARY_NO, P1); SetButtonEvents(P1,1,0,0,0,0,0,0,0); #endif /* Infinite loop */ for(;;) { #if _module == 1 // Perform the dance if (buttonPressed) { RGB_LED_pulseColor(RED, 200, 100, 1); Delay_ms(100); for (uint8_t i=2 ; i<=5 ; i++) { messageParams[0] = 0; // Use color name messageParams[1] = RED; // color // period messageParams[2] = (uint8_t)(200>>24); messageParams[3] = (uint8_t)(200>>16); messageParams[4] = (uint8_t)(200>>8); messageParams[5] = (uint8_t)(200); // duty messageParams[6] = (uint8_t)(100>>24); messageParams[7] = (uint8_t)(100>>16); messageParams[8] = (uint8_t)(100>>8); messageParams[9] = (uint8_t)(100); // repeat messageParams[10] = 0; messageParams[11] = 0; messageParams[12] = 0; messageParams[13] = 1; SendMessageToModule(i, CODE_H01R0_PULSE, 14); Delay_ms(100); } for (uint8_t i=4 ; i>=2 ; i--) { messageParams[0] = 0; // Use color name messageParams[1] = RED; // color // period messageParams[2] = (uint8_t)(200>>24); messageParams[3] = (uint8_t)(200>>16); messageParams[4] = (uint8_t)(200>>8); messageParams[5] = (uint8_t)(200); // duty messageParams[6] = (uint8_t)(100>>24); messageParams[7] = (uint8_t)(100>>16); messageParams[8] = (uint8_t)(100>>8); messageParams[9] = (uint8_t)(100); // repeat messageParams[10] = 0; messageParams[11] = 0; messageParams[12] = 0; messageParams[13] = 1; SendMessageToModule(i, CODE_H01R0_PULSE, 14); Delay_ms(100); } RGB_LED_pulseColor(RED, 200, 100, 1); buttonPressed = 0; // Reset button flag } #endif } } // Button click callback void buttonClickedCallback(uint8_t port) { buttonPressed = 1; }Example 5:
Same concept as ex 4 but with a different dancing pattern on each button. The code looks long and scary but it's all the same code repeated.! As shown there, you can use compiler defines:
#if _module == 1 xxxxxxxxxx #endif
to execute specific code inside a specific module. This saves you the hassle of creating separate projects if all or some of your modules have the same part number.
Example 6:
This example demonstrates the use of remote write API.
Button 1 (connected to Module 1) is used as on/off switch for all LEDs. Button 2 is used to cycle through basic colors (WHITE, RED, BLUE, YELLOW, CYAN, MAGENTA, GREEN). Button 4 is used to increase intensity and Button 5 to decrease intensity (each click is 10%).
All modules define three BOS variables: A bool describing LED status and two UINT8 describing intensity and color. They are initialized to ON, 50(%) and WHITE respectively.
First of all the global variables are linked to BOS variables so that we can use addresses 1, 2 and 3 to address them across the array. Then all four buttons are defined and click event is enabled. Inside the click event, each module performs its task locally (e.g., cycling through colors) then broadcasts a RemoteWrite to the appropriate BOS variable. The indicator LED is also blinked to show the click. Inside the infinite loop, a setColor API is used to control the local LED based on the value of BOS variables shared across the array. This example shows how to use RemoteWrite to control basically everything in the array.
Software Example 1 - Coding 101
03/09/2018 at 20:35 • 0 commentsThis is a simple example to show you the C coding workflow. We will send a broadcast ping message to all five LED modules so that they blink their red indicator LED. The message will be repeated every 500ms.
In FrontEnd task in main.c, write the following before the infinite loop:
#if _module == 1 BOS.response = BOS_RESPONSE_NONE; #endifAnd this inside the loop:
#if _module == 1 SendMessageToModule(BOS_BROADCAST, CODE_ping, 0); Delay_ms(500); #endifRecompile Module 1 and load. Note that the ping message takes zero parameters. The destination module ID (first parameter for SendMessageToModule API) is replaced with BOS_BROADCAST constant to broadcast the message everywhere.
For more information, about implementing these APIs check our BOS documentation.
Hexabitz
