Waste Ink Pad Counter Reset Epson XP, stop Waste Ink Pad error message Free
Epson XP 605 Waste Ink Pad clean and Waste Ink Pad Counter Reset.
The free software suggest it will also work with Epson XP 605, XP 600, XP 700, XP 750, XP 800, XP 850
I would suggest you do need to physically clean the Waste Ink Pads or they could overflow with waste ink once the Waste Ink Counter is reset
I take no responsibility for any damage cause in any way
Epson XP 605 Waste Ink Pad clean.Jump to 24 mins 54 sec. skip to the Waste Pad Software Reset, (free)
Link in to Reset Software description.Epson XP 605 Waste Ink Pad reset.
File, (large size watch two video instructions, in the file) :-
"USE Watch Instructions Video XP600-605_700-750_XP-800-850.zip"
Get it here:-
Link to software here USE Watch Instructions Video XP600-605_700-750_XP-800-850.zip
Should also work on Epson XP 600, XP 700, XP 750, XP 800, XP 850
ONLY do this if you have no other option.
I take no responsibility for any damage cause in any way.
Yours will most likely show different numbers I have already used this successfully.
Watch the two instruction videos in the folder.
Video on Daily Motion. how to:
Films4You
Anteneh Gashaw
touchaddict
ronald
Dominik Meffert
Downoad https://1drv.ms/u/s!AjFFUc7muc09hC8gn3Zmt0pFhY__
