I implemented my project using a Particle Core microcontroller, and WS2812B LED strips, using the Adafruit NeoPixel library. But you should be able to use pretty much any controller and LED type you want. I'm thinking about porting things to use the FastLED library, as well. Hopefully, I can even refactor it with a software shim API that will let you easily choose between using the NeoPixels and FastLED libraries.
dougal
Stephen Tranovich
ZaidPirwani
Roger
Charlie Lindahl
lol..interested...maybe we can try APA107 led source, more stable and cheaper, most important is that we can save much money..lol
