Hackaday.io Hackaday.io
Sign up Log in
upcycling bicycle soda can lamp
upcycling is "in/trendy" but most of these things are more art than of practical use. I like it if things just fit together. KISS.
rawerawe
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
297 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
262
0
297
2
Team (1)
  • rawerawe
Join this project's team
hardware
ongoing project
This project was created on 10/06/2015 and last updated 11 years ago.
Description
I like it if things just fit together "by divine providence".
* LEDs are bright. My LED modules are circular. Soda cans make great lampshades.
* Soda cans got an opener mechanism. It makes a great strain relief.
* There is "botte deposit" on them. The soda cans I got are from Sweden. Sweden got the "Swedish krona". A chandelier is called "krona" in Sweden. Yay, supply stuff for a chandelier laying around?
* a bicycle wheel is made of metal. drill holes, put old coax cable with shield in it, 50% wiring done. Maybe add BNC connectors for easy re-arrangement (and nerdyness)?
* a bicycle wheel got a valve hole. perfect for supply voltage feed-in.
Project Logs
Collapse
  • one: lampshades
    rawe • 11/22/2015 at 19:44 • 0 comments
    LED module attached to coax cable:
    ...fed through tap:
    ... incl. BNC connector:
View project log
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "upcycling bicycle soda can lamp", please tell us the reason.
Send message
Remove Member
