Embedded Development. Easier Than Ever.
- Colourful command-line output
- IDE Integration with Arduino, Eclipse, Energia, Qt Creator, Sublime Text, Vim, Visual Studio
- Continuous Integration with AppVeyor, Circle CI, Drone, Shippable, Travis CI
- Built-in Serial Port Monitor and configurable build -flags/-options
- Pre-built tool chains, Frameworks for the Development Platforms
Smart Code Builder. Fast and Reliable.
- Reliable, automatic dependency analysis and detection of build changes
- Improved support for parallel builds
- Ability to share built files in a cache
- Lookup for external libraries which are installed via Library Manager
The Missing Library Manager. It’s here!
- Friendly Command-Line Interface
- Modern Web 2.0 Library Search
- Library dependency management
- Automatic library updating
- It runs on Windows, Mac OS X, and Linux (+ARM).
Ivan Kravets
● Nitestryker ●
jaromir.sukuba
Is there a public chat for platformio on hackaday?
