- New
test_speed
option to control a communication baudrate/speed between PIO Unit Testingengine and a target device (issue #1273) - Show full library version in "Library Dependency Graph" including VCS information (issue #1274)
- Configure a custom firmware/program name in build directory (example)
- Renamed
envs_dir
option tobuild_dir
in Project Configuration File "platformio.ini" - Refactored code without "arrow" dependency (resolve issue with "ImportError: No module named backports.functools_lru_cache")
- Improved support of PIO Unified Debugger for Eclipse Oxygen
- Improved a work in off-line mode
- Fixed project generator for CLion and Qt Creator IDE (issue #1299)
- Fixed PIO Unified Debugger for mbed framework
- Fixed library updates when a version is declared in VCS format (not SemVer)
