A Small Success
A project log for CAT Board
The CAT Board is part of a Raspberry Pi-based hand-held FPGA programming system.
dave-vandenboutDave Vandenbout 10/15/2015 at 19:366 Comments
I built another CAT Board with a minimal amount of circuitry (i.e., the FPGA, voltage regulators, RESET switch, some pullup resistors) and powered it up. I looked at the SPI clock signal and it had a 7.5 MHz square wave on it. That's exactly what it should do if the FPGA is powering up in master configuration mode and trying to load a bitstream from an external serial flash. I could also toggle the reset and see the FPGA putting out commands to the flash on the SDO line.
I was also able to place the FPGA in the slave serial mode by holding its SPI slave-select pin low while pulsing the reset. So I felt I was ready to try configuring it from the RPi.
I mounted the four LEDs on the CAT Board and then connected the power, ground and SPI signals to the RPi. Then I used the bash script to download the simple LED driver bitstream to the FPGA. Here's a video of the event:
So I've verified that I can create valid iCE40 bitstreams with the iCEcube2 software and download them to the iCE40HX FPGA from the RPi. Now I can assemble the rest of the CAT Board and continue testing with the RPi.
As to what went wrong with the first board I assembled, possibly I toasted the FPGA by heating it too long (2:00 minutes). I heated the second BGA for only 1:30 minutes. As I recall, I ruined the first Xilinx BGA I ever attempted to mount, so I'm keeping the tradition alive.
Rich text editor
Kumar, Abhishek wrote 10/16/2015 at 16:09 point
Glad to know it's working now!
Dave Vandenbout wrote 10/16/2015 at 17:09 point
Thanks! Bringing up a new board is always a pain.
Yann Guidon / YGDES wrote 10/16/2015 at 18:22 point
but it's a worthy adventure !
Dave Vandenbout wrote 10/15/2015 at 22:12 point
Thanks!
I hope I'm not scaring you away from the Lattice FPGAs with all the gory details. It appears most of my problems were related to the BGA assembly, not to the FPGA itself.
Yann Guidon / YGDES wrote 10/16/2015 at 21:49 point
I'm not scared away, on the contrary: your detailed experiences are very helpful to design the circuits and bring them up.
Keep sharing !
Yann Guidon / YGDES wrote 10/15/2015 at 21:14 point
Great work !
