I'm been making some progress on the Altium schematic!
Although mostly complete, there are a lot of annoying "Altium-y" things left to do that mostly revolve around footprint hunting and component selection.
Here is a higher level schematic that more-or-less resembles the initial sketch:
The design is mostly a bunch or repeated power supplies and a signal conditioned from an isolation amplifier (not that it was going to be anything else). What is making it interesting, however, it the power restriction set by the extremely limited space in the enclosure that is forced upon me by the two 1VA transformers:
I think this is going to be a fun layout!
