Circuit Simulations
A project log for Grid-2-Audio
A convenient adapter to view the electrical grid waveform through your PC's sound card.
david-scholtenDavid Scholten 03/31/2018 at 03:150 Comments
Finally had some time to get to work on the circuit design! First off is a tentative power supply with an input filter to ensure harmonics from the grid are minimised:
Taken from a resistive divider on the grid side, voltage measurements are then passed through an isolation amplifier to some op-amp stages for signal processing and buffering:
A standard active 2nd-order high pass op-amp filter:
Having some fun with filters and nifty AC analysis functions in Multisim 12:
Starting to have some fun with this after all!
Rich text editor
