blinky
11/16/2015 at 19:54 • 0 comments -
First board ready and tested
11/16/2015 at 19:10 • 0 commentsThe first board is soldered an tested. I had some problems getting the Atmel BA bootloader running. But now it is working! It now can get programmed via USB.
my test program just blinks the on board user LED which is connected to pin A08. Sadly the ESD protection diodes do not work. I did fixed that with two small wires.
PCBs arrived
10/31/2015 at 15:28 • 1 commentNo much to say just a picture:
I do also have all part allready. Ao the soldering can begin...
Layouting
10/10/2015 at 13:43 • 0 commentsThe layout is ready! I will also set up a Bitbucket repository soon to publish the files. but first here are some pictures:
I also made some renders of the PCB:
If I or someone else do not find any mistake I will sent them to OSH-Park tomorrow.
Alex
