Adjustable mirror
10/28/2015 at 20:50 • 0 commentsThe square mirror frame had some issues with mirror alignment, so I modified the mirror holder and square mirror faces. Now the angle of the mirror can be adjusted. You can get the idea from the photo below. Will post description and update the SCAD files soon...
First photos
10/15/2015 at 18:25 • 0 commentsHere are two photos of the partly assembled cubes.
Top: a square cube with dichroic mirror. Bottom: triangular cube with silver mirror attached to SM1 sense tubes.
Triangular Components
10/14/2015 at 20:39 • 0 commentsI am adding description of triangular components, which are now also available on GitHub.
Wellcome OpenCube
10/11/2015 at 18:42 • 0 commentsThe first version of an OpenCube - based optical setup is nearly assembled (photos to follow). I am adding the description of a project, including square components and uploading OpenCube.scad and OpenCubeSetup.scad files to github.
Mihails Delmans
