My code bitbucket for the native esp8266 dev environment.
To enable GPIO pin5:
gpio_init();
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO5); //enable pin5 GPIO
PIN_PULLUP_EN(PERIPHS_IO_MUX_GPIO0_U); //Enable pullups
Then to enable a timer to callback and read the value:
// TIMER STUFF
//Setup timer callback
os_timer_setfn(&buttonTimer, (os_timer_func_t *)buttonTimerCB, NULL);
//Arm the timer
//&buttonTimer is the pointer
//35 is the fire time in ms
//0 for once and 1 for repeating
os_timer_arm(&buttonTimer, 35, 1);
Then the timercallback function:
uint16_t pinvalue=0;
void buttonTimerCB(void *arg){
//INFO("Timer says hi!");
pinvalue = GPIO_INPUT_GET(GPIO_ID_PIN(5));
if(pinvalue){
pressCount = pressCount+1;
INFO("Button pressed #%d \r\n", pressCount);
