GPIO Code
10/16/2015 at 03:16 • 0 commentsTo enable GPIO pin5:
gpio_init(); PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO5); //enable pin5 GPIO PIN_PULLUP_EN(PERIPHS_IO_MUX_GPIO0_U); //Enable pullupsThen to enable a timer to callback and read the value:
//=================================== // TIMER STUFF //=================================== //Setup timer callback os_timer_setfn(&buttonTimer, (os_timer_func_t *)buttonTimerCB, NULL); //Arm the timer //&buttonTimer is the pointer //35 is the fire time in ms //0 for once and 1 for repeating os_timer_arm(&buttonTimer, 35, 1);Then the timercallback function:
uint16_t pinvalue=0; void buttonTimerCB(void *arg){ //INFO("Timer says hi!"); pinvalue = GPIO_INPUT_GET(GPIO_ID_PIN(5)); if(pinvalue){ pressCount = pressCount+1; INFO("Button pressed #%d \r\n", pressCount); } }
ril3y
